Other than for a potential weight saving, does anyone have an argument that supports using Futaba's S-BUS (or any or CAN type system) as opposed to using conventional servo wiring-up?
One downside consistantly noted by folk is that if you loose one connection, you loose control over all servo's on that extension from that point onwards - which has the potential to be fatal, but, given the care that folk go to when it comes to wiring up, just how much more likely are you to run into such a scenario? Afterall, the potential to loose a connection and run into a fatal situation is no more/less likely with conventional wiring, is it?
Patrick
