OK.. I have built 10-15 tri,hex,octo… ect all with AMP 1 2 2.5…
All worked fine…for the most part..
Now I am building generator-copter… 23CC gas motor powering a 2000 watt brushless motor..
To date the generator has produced over 1100 watts…. 70 amps at 16 volts…
Test results show at this weight I need 7-800 watts to lift this noisy beast…
A few days ago I was ready to start testing the copter itself… APM 2.5… Hex… with 17” CF props
http://www.rcgroups.com/forums/showthread.php?t=1795491&highlight=www+jetlen+com
But major problem… ESC’s will not arm on power up….. When plugged directly into receiver… They Arm no problem, and calibrate like normal…and run the motors..
then I plug them into the APM 2.5… nothing… I get 3 beeps... thats it...
I Measure the PW on the output rail… 1002ms… I plug a servo into the output rail… works great… Arm the APM 2.5.... power up… servo moves…ok
I plug the APM into the usb, the APM boots up…. Then I plug in the Main power… 4S with 5 volt BEC… ESCs boot up no problem, and I can run the motors…
Summay… The ESCs only ARM when the APM is power up first !!!....whats up with that….??
Here is the setup…
APM 2.5… tried 2 different ones… 2.9.1
All ESC have the red wire cut…
5 volt set to 4.9 and 5.2….. no difference..
Jumper installed… not installed… even jumped the power from the input rail to the output rail like I always do… nothing….
Detrum 25A ESC 2-6S
Hitec receiver…
Thanks for your help...
Eddie Weeks
Really great design.
Just a few thoughts Eddie,
Do you normally have a battery in the system?
If you do not have a battery is there any sort of regulation that prevents power from going to the APM before it is at least at 5 volts and smooth?
If the answer to both above is no then you are attempting to bring up voltage slowly to the APM, and ESC's.
This means that the ESCs will be out of sync with the APM while powering up and will not initialize properly.
Also very not good to power APM with less than 5 volts, it may not self initialize properly at all.
I honestly think that the prospect of powering the APM from a small separate battery (and UBEC) is an easy solution, you could always include a small charger circuit for the battery, but the smooth power could really help.
If you do that definitely use at least a 2 cell LiPo and a UBEC rather than trying to power the APM from a 4.8 volt battery.
This is a really great project that could yield really long flight time Multicopters and I wish you all the best and can't wait to see it flying.
Damn just sold my Traxxas Monster Buggy too, I always knew that Zenoah engine could be good for something.
It sounds like the ESC's are not seeing the right voltage when they are armed.
How do you initiate switch on, is it just ramping up the motor/generator until voltages get high enough to power everything, or do you ramp up the motor/generator to voltage and throw a switch?
BTW.... I could just plug a 4.8 volt batt into the receiver then power up the copter... that works...
But I want this to be done right..
Just saying
