Gimbal motors for driving propellers
Hello all,
I'm looking for brushless motors with a hollow shaft to drive a propeller. The only motors I can come up with such hollow shafts are gimbal motors.
My question to you, is there anything against it to use gimbal motors to drive propellers? I haven't seen it happening except for this one: http://www.hobbyking.com/hobbyking/store/__61431__DYS_Brushless_Motor_BE8108_16_100KV_for_Multi_Rotors_Gimbals.html
What makes this gimbal motor different from the rest that it can be used for driving a propeller?
I'm looking forward to your replies!
Arjan
  • Gimbal motors have very low kv. They won't produce enough rpm to swing a prop. There are a few counter rotating setups that may have the shift you are looking for, or just have one made.
  • Gimbal motors tend to be rated at about 2Amps and have 80turns or so of wire, and limited to about 12v.
    The linked motor is capable of 8.6A, with a Kv of 100, for 6s (24v) to 12S (48v). It is for large slow turning props (23" on 6 cells, 18" on 12cells).
    Peter
  • Anyone? Did I post my question in the right category?
