Hello, I've just installed my new gimbal (This one) and it works great! But I'm trying to add the Ch_6 function to control the tilt. It works great but only in +-30º if I pass those angles it starts to shake and goes crazy... It works great if I pass over those angles tilting the copter manually.
Thanks for you help !
One more question, do you know if there is an upgrade to this board to a better firmware?
Check the balance of your gimbal, it sounds like it is node/tail heavy which is beyond the capabilities of the brushless motors.
It will of course work fine if the copter is tilted because it is not trying to lift any weight.
Brushless gimbals should be absolutely evenly balanced so the camera can be tilted by hand to any angle (with the power off) and it will stay there.
If it swings back to any position then you need to balance it better.
