Well I guess they call themselves, 'Goodluck Buy', for a reason. Unfortunately I was out of luck, I bought two 433mhz antennas in the hope they would improve my range/rssi. Infact, they smoked my air module.
The lengths appear all wrong, and the resistance is far to low (20 ohms). Is it possible to solder more wire onto the active element to tune them or is it better to throw them?
3691083963?profile=original
The good news, is that my micro radio bridge works superbly and supports both USB and Bluetooth modes through the side switch.
  • Chris,
    I'm making my antennas from pieces of coax cable salvaged from dillapidated laptops. The ones running to the WiFi antennas on the top lid above the screen.
    I'm running my telemetry in 868MHz, and my quarter wavelength is 82mm. So I just cut a 167mm length of said cable, strip 3 mm from both outer and inner conductor to solder on the radio module (less connectors that can rip in a crash) and from the remaining 164mm I strip the outer insulation and shield on 82mm. Then I add some heatshrink over it to straighten and harden it, and let it dangle from the craft.
    It works really well. I've had a radio-loss RTL from behind a line of trees once, but telemetry was still solid.
    Your working with 433MHz will double all the sizes and will yeld a pretty long antenna, but it's doable, and unless it hinders some 360-deg pan camera it won't feel like a PITA.
  • Just a note on the Goodluck buy guys on ebay.  They run under several names in fact. And yeah, their stuff and their service or shipping is hit or miss. I have dealt with them a few times. I am with Marcin Karawczyk on this one.
  • How did you measured "resistance"?
    You shouldn't smoke module even if you'll connect simple piece of wire (of course if it not shorts antenna pin to ground)...
