  • I will give it a go. I did not use the bind plug!
    You are not calibrating the Sensor, for that you must insert the bind plug (set home).
  • yes I do I am re reading th manaul again!! I had my first flight yesterday or should I say first fright
    paul
    Do you have the silicon tube in the top nipple?
  • Does the "digital" number readout in the lower half of the gauge actually read 200 or does the "analog" dial point to 200?
