Ground station wrong distance readout
I am running ver 2 groundstation which seems to be working ok, except the distance field it always reads 58074 Mtrs and do not have the xyz sensors yet waiting for them to become available, any idea what the problem is
  • As I do not have the xyz sensors can I fool the ground station because I have a perminant 60 degree bank if the sensors put out an analog signal I was thinking I could substitue this to level up the g/station which will make my servos respond better
  • I think you have to be in Waypoint mode for the distance to compute, thus have WP list loaded with the Config Utility. You've all that done? Or can your 1st turning waypoint be 58 km away?
