  • Oh thank god, somone else wants to. :) I have had a terrible time getting info on this. The best I've come up with, is prove that 50mhz RC gear exists, its just hard to find, and expensive when you do, but feasibly COULD be ran through a 6 meter amplifier.
    As for amateur TV, I looked into that as well. 5 watts for 200 bucks, but as aforementioned, anyone can watch it. You just tune a cable ready SD TV to the right channel.
    Then, I also found a telemetry thing for HAM, or really any audiio stream, that is really cheap and uses an Atmel chip. My eventual goal is to send telemetry over the audio stream for the HAMTV. ;) Its just Packet radio, but I have NO idea how to do any of it.
    Could we use packet to control the plane??
    Tim
  • There's an overlap between the 2.4 GHz Amateur Radio allocation, and 2.4 GHz ISM band that WiFi uses; check out amateur radio "hinternet".
  • I'm sure technically you could but its unlikely you will find anything using those bands for UAV control being sold by anyone so that may mean having to design and build it yourself. That itself might lead to problems in the size of the receiver and the intended plane. The radio range of such a setup would be far more than anything us Xbee users could hope for. If you do find a way make sure you also have standard RC gear attached just in case.
