Heading function to replace compass
Hi all, Resent days RTK becoming Very popular and I came across some function called Heading to True North.
The RTK module is enabled with two antenna facing in the same direction and gives Heading Accuracy (RMS) 0.2° (1m baseline) as bellow. I can log this data along with GPGGA msg from the RTK GPS module through UART.
Hope this data can support the compass function for a better flight.
I request support to read this header msg and use it for compass function.
$GNHDT,178.7236,T*15 (<Log header>,< Heading angle>,< True North>,< *Checksum>)
#HEADINGA,COM1,0,29.0,FINE,1740,367835.000,00000000,e,0;SOL_COMPUTED,NARROW_INT,0.0014,286.2120,41.0552,0.0000,416.9299,654.8104,"0",20,17,17,17,0,01,0,c3*ce3d9c8e
Field
Field
Data Description
Format
Bytes
Offset
1
HEADING header
Log header
H
0
2
sol stat
Solution status, see Table 21
Enum
4
H
3
pos type
Position type, see Table 20
Enum
4
H+4
4
length
Baseline length (0 to 3000 m)
Float
4
H+8
5
heading
Heading (0 to 360.0 degrees)
Float
4
H+12
6
pitch
Pitch (±90 degrees)
Float
4
H+16
7
Reserved
Float
4
H+20
8
hdgstddev
Heading standard deviation
Float
4
H+24
9
ptchstddev
Pitch standard deviation
Float
4
H+28
10
stn id
Base station ID
Float
4
H+32
11
#SVs
Number of tracked satellites
Uchar
1
H+36
12
#solnSVs
Number of satellites in use
Uchar
1
H+37
13
#obs
Number of satellites above the elevation cut-off angle
Uchar
1
H+38
14
#multi
Number of satellites above elevation cut-off angle with L2
Uchar
1
H+39
15
Reserved
Uchar
1
H+40
16
ext sol stat
Extended solution status, see Table 29
Uchar
1
H+41
17
Reserved
Uchar
1
H+42
18
sig mask
Signal mask, see Table 22
Uchar
1
H+43
19
xxxx
32-bit CRC (ASCII and Binary only)
Hex
4
H+44
20
[CR][LF]
Sentence terminator (ASCII only)
_
_
_
  • Posting to discuss.ardupilot.org would be better.
