Pixhawk Crash Analysis
Date:19-05-2017
Time: 4 – 7 p.m.
Weather: Calm, sunny day & with no or little wind
Temp: 37-32 C
Plane: Volantex Ranger
Board: 3DR Pixhawk loaded with plane 3.7.1
Battery: DIY 3s pack 20400Mah made from Panasonic ncr18650b
After programming the board, today was the first test flight. I took off in manual mode, trimmed the plane and flown it for almost 10 to 15 minutes in manual mode without any problem.
Then I switched to FBWA mode the plane handled the flight very well with the stock parameters and without any tuning at all. Then I switched to FBWB mode and the result was great flight. After that I switched to cruise mode where I faced only one issue: The plane was holding the flight path really well but with some roller coaster motion (something that I know is having to do with tuning). After that I switched to loiter and the plane started performing good circles thought I haven’t calibrated the airspeed yet. Only then and after making sure that the plane can fly itself I switched to RTL mode and the plane came back to me and started loitering at 200m altitude which I had set for RTL altitude.
Now it was the right time to start the auto tuning progress. I went ahead and did the roll tuning, then the pitch tuning and everything was good. After that I checked the tuning page on my mission planner and the parameters were changed to the new set of the auto tuning. Afterwards I started applying rudder inputs to tune the yaw and here the problem started. After few rudder inputs the plane stopped responding and went into a turn towards the ground with the rudder stock in one end. While the plane was going down I switched out of Auto tune and tried all the modes but without getting any response from the plane even in manual mode.
It was at that moment when the plane sat on the green field about 500 meters away from me. When the plane hit the ground the radio announced “RSSI CRITICAL”.
When I reached the plane opened the canopy the led indicator of Pixhawk was indicating failsafe. The plane wasn’t damaged at all and I didn’t notice any damage to the electronics as well. Of course I haven’t checked anything yet.
I had the screen recorder on my laptop recording the screen and now when I came to see the last seconds before the crash I realized few things that I wasn’t aware of as I had the sound muted on my laptop.
31’ 20” in to the flight started the yaw tuning
31’ 27” in to the flight 3 yaw inputs so far
31’ 28” in to the flight bad AHRS
31’ 29” in to the flight error caused vert variance
31’ 36” in to the flight 6 yaw inputs and I realized that something is not OK with plane
31’ 39” in to the flight warning no data for 10 seconds
31’ 40” in to the flight changed to other modes
31’ 44” in to the flight earning no data for 15 seconds
31’ 46” in to the flight I was sure that the plane is not responding at all
31’ 55” in to the flight warning no data for 25 seconds
32’ 05” in to the flight RSSI critical (from Taranis)
32’ 08” in to the flight Telemetry lost (from Taranis)
32’ 21” in to the flight Telemetry recovered (from Taranis)
32’ 23” in to the flight Telemetry lost (from Taranis)
32’ 42” in to the flight No RC Receiver
Error caused vert variance
Bad AHRS
Error compass variance
Same errors continued for several minutes till I reached the plane and turned it off.
Telemetry Recovered, RSSI critical, Telemetry Lost, ….
Now when I connect the Pixhawk to the PC I get a solid red light and I cannot get it to connect to mission planner.
I’ll try to go through all the components one by one to see if I can detect any error or issue starting from tonight.
Guys, please give me your thoughts and ideas on what could be the cause
Many Thanks
Tom Pittenger said:
The problem that I have now is that I'm unable to get the pixhawk to connect to mission planner. The red solid light is indicating an error. I've tried to flash different firmware but nothing happened. I've tried flashing the px4 pro using QGround Control. It works and the solid red changes to blinking red and it won't go off.
The BOOT file located on the SD card says:"no px4io board found"
I've tried flashing the master firmware it works but still the error on the mission planer is:"no px4io board found"
Any ideas on how can I solve the issue?
Tom Pittenger said:
Andre K. said:
Log shows it as a power failure. Power overload, not a software problem.
please post .tlog for that flight (telemetry log, stored by your GCS)
here is the link:
https://github.com/ArduPilot/ardupilot/issues/6300
Hopefully, something good, will be the result of this crash/very creative use of autotune :)
That 72 second interval has no log entries; between log index 1527975 and 1527976, TimeUS jumps from 2070 seconds to 2141 seconds.
Andre K. said:
Andre K.
Like Graham already pointed out, there is no yaw tuning, and if you rolled plane enough, using rudder, it could very well get some crazy PIDs - but there's something worse heppening here.
There are some 72 seconds between the failsafe kicks in, and the crash, where there is no elevator/aileron movement, not even a realistic change in elevation (GPS & baro) or attitude. Basically, much of the data and control surfaces are just frozen during the descend.
I'll create a issue on github for this case. suspecting a nasty bug somewhere.
1
2
3
of 3 Next
