When I go to calibrate my battery monitor mission planner, the box where you elect the sensor does not stay elected on 3dr power module.  It reverts back to "other".  It is a Original 3DR power module and I'm using it with an apm 2.5.  I think because of this problem the OSD minim is not reading the correct voltage and current %.  Any help would be appreciated.
  • Admin
    @Chris,
    What version of MP are you using at the moment?
    TCIII AVD
    • This APM 2.5 and power module are being used in a Diatone White sheep frame, along with 3DR 850 motors and 3DR ESC's.  The version of Mission Planner I'm using is 1.3.31
  • anybody have any ideas about this problem?
    • On an IRIS+?
      I'm not having this issue and I'm running the latest beta on my IRIS (3.3rc8) and the latest MP (1.3.31).
      I can think of 2 things that you can do; 1) reload the default IRIS+ parameters, write them, reboot and see what it says, or 2) go into the full parameter list and verify your settings there.  Careful with the full parameter list as it's easy to mess up something.  http://copter.ardupilot.com/wiki/arducopter-parameters/#batt__param...
      -Mike
