HK GCS Error when calibrating Tracking servos
I get the following error when I click the Save box after calibrating the servos - Any suggestions?
Peter:
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************System.InvalidCastException: Conversion from string "" to type 'Integer' is not valid. ---> System.FormatException: Input string was not in a correct format.   at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDouble(String Value, NumberFormatInfo NumberFormat)   at Microsoft.VisualBasic.CompilerServices.Conversions.ToInteger(String Value)   --- End of inner exception stack trace ---   at Microsoft.VisualBasic.CompilerServices.Conversions.ToInteger(String Value)   at HK_GCS.frmTrackingCalibrate.cmdSave_Click(Object sender, EventArgs e)   at System.Windows.Forms.Control.OnClick(EventArgs e)   at System.Windows.Forms.Button.OnClick(EventArgs e)   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)   at System.Windows.Forms.Control.WndProc(Message& m)   at System.Windows.Forms.ButtonBase.WndProc(Message& m)   at System.Windows.Forms.Button.WndProc(Message& m)   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************mscorlib    Assembly Version: 2.0.0.0    Win32 Version: 2.0.50727.4952 (win7RTMGDR.050727-4900)    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll----------------------------------------Ground Control Station    Assembly Version: 1.2.38.0    Win32 Version: 1.2.38    CodeBase: file:///C:/Program%20Files%20(x86)/HappyKillmore/GCS/Ground%20Control%20Station.exe----------------------------------------Microsoft.VisualBasic    Assembly Version: 8.0.0.0    Win32 Version: 8.0.50727.4927 (NetFXspW7.050727-4900)    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll----------------------------------------System    Assembly Version: 2.0.0.0    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll----------------------------------------System.Windows.Forms    Assembly Version: 2.0.0.0    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll----------------------------------------System.Drawing    Assembly Version: 2.0.0.0    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll----------------------------------------System.Runtime.Remoting    Assembly Version: 2.0.0.0    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll----------------------------------------DirectShowLib-2005    Assembly Version: 2.1.0.0    Win32 Version: 2.1.0.0    CodeBase: file:///C:/Program%20Files%20(x86)/HappyKillmore/GCS/DirectShowLib-2005.DLL----------------------------------------Interop.GEPlugin    Assembly Version: 1.0.0.0    Win32 Version: 1.0.0.0    CodeBase: file:///C:/Program%20Files%20(x86)/HappyKillmore/GCS/Interop.GEPlugin.DLL----------------------------------------System.Data    Assembly Version: 2.0.0.0    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)    CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll----------------------------------------System.Xml    Assembly Version: 2.0.0.0    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------Microsoft.DirectX.DirectInput    Assembly Version: 1.0.2902.0    Win32 Version: 5.04.00.2904    CodeBase: file:///C:/Windows/assembly/GAC/Microsoft.DirectX.DirectInput/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.DirectInput.dll----------------------------------------Microsoft.DirectX.Direct3DX    Assembly Version: 1.0.2902.0    Win32 Version: 5.04.00.3900    CodeBase: file:///C:/Windows/assembly/GAC/Microsoft.DirectX.Direct3DX/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.Direct3DX.dll----------------------------------------Microsoft.DirectX.Direct3D    Assembly Version: 1.0.2902.0    Win32 Version: 9.05.132.0000    CodeBase: file:///C:/Windows/assembly/GAC/Microsoft.DirectX.Direct3D/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.Direct3D.dll----------------------------------------Accessibility    Assembly Version: 2.0.0.0    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll----------------------------------------Microsoft.DirectX    Assembly Version: 1.0.2902.0    Win32 Version: 5.04.00.2904    CodeBase: file:///C:/Windows/assembly/GAC/Microsoft.DirectX/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.dll----------------------------------------
************** JIT Debugging **************To enable just-in-time (JIT) debugging, the .config file for thisapplication or computer (machine.config) must have thejitDebugging value set in the system.windows.forms section.The application must also be compiled with debuggingenabled.
For example:
<configuration>    <system.windows.forms jitDebugging="true" /></configuration>
When JIT debugging is enabled, any unhandled exceptionwill be sent to the JIT debugger registered on the computerrather than be handled by this dialog box.
  • Thank you HK - I will give it a try.
    Peter
