I have this battery: http://www.hobbypartz.com/98p-65c-5000-2s2p-hardcase.html
The battery cables that go to my PDB on the hexacopter have a male deans connector, but this battery seems to have bullet connectors.  Can I just cut them off and solder a female deans connector?
Also, attached to the bullet connectors on my battery, there is a smaller diameter wire with a white clip., seen here: http://ep.yimg.com/ca/I/yhst-62196343123315_2237_15595252
What is this and where does it go on the hexacopter?
thanks,
Wolfgang
  • T3
    Be careful when cutting the wires.  Make sure you cut the positive and negative seperately.  If you cut them together you will short out the battery and destory the battery.  I also recommed 3S 5000 mAh.
  • You will need at least a 3S battery for a hexacopter, probaby better off with a 4S.
    You could get another one of the same and run them in series.
