We want a drone with a camera capability to produce a GSD of around 0.3mm at 20m altitude. This could be achieved with a 20Mpix SLR with optical zoom of 10x, but how feasible is the build?  Could it be undertaken by a highschool robotics group?
  •   Thanks Jeremy.  The idea is that we'd be flying at low velocity to identify trails, then just hover directly over a footprint to image that detail. But yes, I'm thinking that a Matrice would provide reasonable stability - using two different cameras - one to locate trails, and the other with a high zoom to capture individual footprints.
    Jeremy Randle said:
    With a GSD of 0.3mm, if you could achieve a shutter speed of 1/1000 (unlikely) then a velocity of even 0.3 metres per second (300mm/sec) would give you motion blur of 1 pixel !! At 20 metres altitude an angle change of 0.9deg/sec would give you motion blur of 1 pixel !!
    You will need a very, very steady platform.
  • With a GSD of 0.3mm, if you could achieve a shutter speed of 1/1000 (unlikely) then a velocity of even 0.3 metres per second (300mm/sec) would give you motion blur of 1 pixel !! At 20 metres altitude an angle change of 0.9deg/sec would give you motion blur of 1 pixel !!
  • Yes, that's what I meant.
    Thanks Andre!
    Andre K. said:
    "Coordinate with such camera ?"  - I do not know what you mean, but in any case, you do not need to depend on any proprietary, limited flight controller to do that.
    WildTrack said:
    Also is the Matrice the only system that comes ready to coordinate with this camera?
  • "Coordinate with such camera ?"  - I do not know what you mean, but in any case, you do not need to depend on any proprietary, limited flight controller to do that.
  • I'd just like to check though, on closer inspection the Sony RX100 is 20Mpix but only has a 3x optical zoom. Is there a camera with a higher optical zoom?  Also is the Matrice the only system that comes ready to coordinate with this camera?
    Crady von Pawlak said:
    I think that would be an excellent combination
    WildTrack said:
    Thanks.  The Sony RX100 on a Matrice might then be the best option.
  • If it should give good data on a cloudy day, you need rx100 or bigger sensor, not a toy.
    Another thing you need to do right, is stabilisation, as such GSD will be very prone to motion blur. So a good brushless stabilisation will be a suitable side project. Start of by calculating.
  • I think that would be an excellent combination
  • Thanks.  The Sony RX100 on a Matrice might then be the best option.
  • No, I don't believe the P4 has optical zoom.
  • Thanks Crady.  We're interested in building and testing for the specific application - imaging animal footprints on the ground, see ConservationFIT.org for more information.
    The Sony RX100 has an optical zoom so that looks promising, but the DJI Phantom surely not?
    IMHO the feasibility of your project is limited only by your budget and the supervision of someone with basic electronics skills.
    As for the camera, a DSLR might be overkill (and certainly a very heavy payload).  Perhaps something light like a late model Sony RX100 w/20MP would be adequate.
    If you're more interested in the end product rather than building from scratch then perhaps you could convince DJI to donate a Phantom 4 Pro or even an Inspire to your school.  Either of those should fulfill your requirements.
    http://ConservationFIT.org/
