We want a drone with a camera capability to produce a GSD of around 0.3mm at 20m altitude. This could be achieved with a 20Mpix SLR with optical zoom of 10x, but how feasible is the build? Could it be undertaken by a highschool robotics group?
Thanks Jeremy. The idea is that we'd be flying at low velocity to identify trails, then just hover directly over a footprint to image that detail. But yes, I'm thinking that a Matrice would provide reasonable stability - using two different cameras - one to locate trails, and the other with a high zoom to capture individual footprints.
Jeremy Randle said:
With a GSD of 0.3mm, if you could achieve a shutter speed of 1/1000 (unlikely) then a velocity of even 0.3 metres per second (300mm/sec) would give you motion blur of 1 pixel !! At 20 metres altitude an angle change of 0.9deg/sec would give you motion blur of 1 pixel !!
You will need a very, very steady platform.
Yes, that's what I meant.
Thanks Andre!
Andre K. said:
"Coordinate with such camera ?" - I do not know what you mean, but in any case, you do not need to depend on any proprietary, limited flight controller to do that.
WildTrack said:
I'd just like to check though, on closer inspection the Sony RX100 is 20Mpix but only has a 3x optical zoom. Is there a camera with a higher optical zoom? Also is the Matrice the only system that comes ready to coordinate with this camera?
Crady von Pawlak said:
Another thing you need to do right, is stabilisation, as such GSD will be very prone to motion blur. So a good brushless stabilisation will be a suitable side project. Start of by calculating.
I think that would be an excellent combination
WildTrack said:
Thanks. The Sony RX100 on a Matrice might then be the best option.
No, I don't believe the P4 has optical zoom.
Thanks Crady. We're interested in building and testing for the specific application - imaging animal footprints on the ground, see ConservationFIT.org for more information.
The Sony RX100 has an optical zoom so that looks promising, but the DJI Phantom surely not?
1
2
of 2 Next
