Just recently I bought RFD900 telemetry as ground and my existing 3DR 915 telemetry as onboard telemetry. try to connect but couldn't. Anyone has done it before? Pls help thank you.
Thomas J Coyle III Ok thanks. I bought the RFD900 from goodbuylucky Im not sure if it is backwards but it came along with two big antennas so I supposed its must be for ground use.
Luke Hovington > Stanley Anak SuabJuly 29, 2015 at 5:00pm
Managed somehow reboot by uploading the version 1.6 firmware usingRFD900 modem tools
@Stanley
The default ID is 25.
Who did you buy the RFD900 telemetry radio from?
If you got it from JDrones, the TX and RX are backwards from the 3DR telemetry radios.
TCIII AVD
This modem is the new 900+
Firmware for these can be found here -> http://files.rfdesign.com.au
I recommend loading the RFDSiK V1.9 rfd900p.ihx onto these modems.
Your non RFD modems should also connect if all the settings are the same.
The manual also goes into what settings need to be the same for a successful link.
