How to output a PPM signal channel from RX to a PWM Output?
Hey there,
I have just spent hours to find out how to use one of the APM 2.5 PWM outputs as a relay for one PPM input channel.
Task is to control a FPV camera which has a PWM input for mode selection. My RX has 4 PWM channels but is used as 8 channel PPM source. All TX channels are available and calibrated in Mission Planner and APM is controlling a quad.
What I wish to achieve is that TX channel 8 from within the PPM signal is forwarded to let's say OUT8 as PWM.
How is this possible?
For now I found the parameter RCx_FUNCTION with the value 1, meaning RCPassThru. This sounds pretty much like what I'm looking for and so I set RC8_FUNCTION = 1 and connected my cameras contol input to OUT8. But changing TX channel 8 does nothing on the camera. Is there something I have missed here?
Thanks & best regards,
Peter
  • any idea how I can change the tail servo for a tricopter from #7 output on APM to #8 somehow?
  • Any update on this? I'm trying to do the same thing except I have all the 8 motor outputs used as I'm on an octo
  • I know you can read RC signals (PPM and PWM) using the PulseIn function. I'm still figuring this out myself, but PulseIn might be a good place to start looking. Once you have the signal you could pass it through manually or apply whatever logic you wish, I presume.
  • I am also having problem with this, I trigger a camera connected in channel 7 manualy for testing purpose, lately I wish it controlled by apm to trigger it thought missions, as now I cant control channels thought output, is there anything we should do?
  • Just found this Issue on GitHub.
    Actually I try to use the Boscam Cobra HD which is controlled the same way as the HD19 which was mentioned in Issue #286.
    Does it mean that RCPassThru is not yet working at all in ArduCopter? Or is it supposed to work on other channels but not yet on channel 6?
