I had a lot of trouble getting mission planner to run correctly on my linux 64bit debian sid system.
After lots of fiddling and tweaking I found installing ONLY mono-runtime and libmono-winforms2.0-cil makes mission planner run fine.
So for those of you wanting to run mission planner on debian (usually valid for ubuntu too):
apt-get install mono-runtime libmono-winforms2.0-cil
will probably do the trick.
After that you should assiociate it with mono to start from the file manager or just run
mono ArdupilotMegaPlanner10.exe
from the commandline.
Hi
In whith serial port can I connect it??
thx
Unfortunately version 1.2.12 of the mission planner does not work anymore on mono due to a mono bug. Version 1.2.14 does show an error message:
And after this a black screen is show. If you click on the navigation tab the naivgation screen is show, and if you click on Flight data tab again the flight data screen is shon, but is no responding.
So unfortunately, no luck yet...
Unfortunately it fails on my computer:
INFO Program - ******************* Logging Configured *******************
INFO ArdupilotMega.MainV2 - Mainv2 ctor
INFO ArdupilotMega.MainV2 - myview width 1008 height 461
INFO ArdupilotMega.MainV2 - this width 1193 height 617
INFO ArdupilotMega.Utilities.Speech - TTS: init, mono = True
INFO ArdupilotMega.Controls.HUD - Vendor: ATI Technologies Inc.
INFO ArdupilotMega.Controls.HUD - Version: 3.3.11566 Compatibility Profile Context
INFO ArdupilotMega.Controls.HUD - Device: ATI Mobility Radeon HD 3400 Series
HUD resize 292 219
HUD 1 hz drawtime 319 gl True
HUD resize 292 219
HUD resize 292 219
HUD resize 292 219
FATAL ArdupilotMega.MainV2 - System.NullReferenceException: Object reference not set to an instance of an object
at System.Windows.Forms.Control+ControlCollection.Add (System.Windows.Forms.Control value) [0x00000] in <filename unknown>:0
at Crom.Controls.Docking.FormsDecoratorControlCollection..ctor (System.Windows.Forms.Control owner) [0x00000] in <filename unknown>:0
at Crom.Controls.Docking.FormsDecorator.get_InternalControls () [0x00000] in <filename unknown>:0
at Crom.Controls.Docking.FormsDecorator.CreateControlsInstance () [0x00000] in <filename unknown>:0
at System.Windows.Forms.Control..ctor () [0x00000] in <filename unknown>:0
at Crom.Controls.Docking.FormsDecorator..ctor () [0x00000] in <filename unknown>:0
at (wrapper remoting-invoke-with-check) Crom.Controls.Docking.FormsDecorator:.ctor ()
at Crom.Controls.Docking.FormsTabbedViewControlCollection..ctor (System.Windows.Forms.Control owner) [0x00000] in <filename unknown>:0
at Crom.Controls.Docking.FormsTabbedView.get_InternalControls () [0x00000] in <filename unknown>:0
at Crom.Controls.Docking.FormsTabbedView.CreateControlsInstance () [0x00000] in <filename unknown>:0
at System.Windows.Forms.ScrollableControl..ctor () [0x00000] in <filename unknown>:0
at System.Windows.Forms.ContainerControl..ctor () [0x00000] in <filename unknown>:0
at System.Windows.Forms.UserControl..ctor () [0x00000] in <filename unknown>:0
at Crom.Controls.TabbedDocument.ButtonsPanel..ctor () [0x00000] in <filename unknown>:0
at Crom.Controls.Docking.FormsTabbedView..ctor () [0x00000] in <filename unknown>:0
at (wrapper remoting-invoke-with-check) Crom.Controls.Docking.FormsTabbedView:.ctor ()
at Crom.Controls.Docking.FormsDocker.CreateFormsTabbedView (Size size, Crom.Controls.Docking.ControlPositioner positioner) [0x00000] in <filename unknown>:0
at Crom.Controls.Docking.FormsDocker.Add (System.Windows.Forms.Form form, zAllowedDock allowedDock, Guid formIdentifier) [0x00000] in <filename unknown>:0
at Crom.Controls.Docking.DockContainer.Add (System.Windows.Forms.Form form, zAllowedDock allowedDock, Guid formIdentifier) [0x00000] in <filename unknown>:0
at (wrapper remoting-invoke-with-check) Crom.Controls.Docking.DockContainer:Add (System.Windows.Forms.Form,Crom.Controls.Docking.zAllowedDock,System.Guid)
at ArdupilotMega.GCSViews.FlightData.CreateFormAndGuid (Crom.Controls.Docking.DockContainer dock, System.Windows.Forms.Control ctl, System.String configguidref) [0x00000] in <filename unknown>:0
at ArdupilotMega.GCSViews.FlightData.SetupDocking () [0x00000] in <filename unknown>:0
at ArdupilotMega.GCSViews.FlightData..ctor () [0x00000] in <filename unknown>:0
at (wrapper remoting-invoke-with-check) ArdupilotMega.GCSViews.FlightData:.ctor ()
at ArdupilotMega.MainV2..ctor () [0x00000] in <filename unknown>:0
False
False
False
