Our next Virtual Race will be on June 4th:
https://www.meetup.com/DIYRobocars/events/285787423?utm_medium=referral&utm_campaign=share-btn_savedevents_share_modal&utm_source=link
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Here is the parameters I've got tuned up right now. Working pretty good. NTN motors and plush amps. 10x4.7 APC props, sonar and optical flow.
http://www.filedropper.com/ht-fpv
Hi HT-FPV guys!
I also have a frame like this, but i'm having problems with my parameters. Could you please share you parameters file with me ? :)
Tommy
The reason for the adapter is that the APM2 has a hole spacing that doesn't match any of the holes already built into the HT-FPV frame, and I didn't want to drill additional holes. You could double-sided tape the APM2 onto the frame, but I also wanted a solution that didn't involve tape and also provided the appropriate circuitry to let me select which ESC I wanted to use to power the APM2 without needing to actually cut wires on the ESCs.
The adapter board mates with the APM2's hole spacing and then provides a 45x45 and 60x60mm hole spacing which fits nicely onto the mounts available on the HT-FPV. It should work fine for other frames, too.
I've got two of the adapter boards spare (I was sent three), so if you want one, PM me and I'm sure we can work something out :)
EDIT: First flight went fine - no issues. Needs some PID tuning, but other than that, everything went great. Flies quite nicely, very responsive, and altitude hold works great. I'll be testing loiter this weekend.
Hi James,
I'm really interested in your project.
I have been looking at frames for a while now and decided to use the HT-FPV frame and APM2. I don't have much experience...hold on...I don't have any experience but your project is exactly what I want to do. Lucky I stumbled across your post.
I don't understand the reason for the adapter board as far as connecting to the frame.
Looking forward to your update.
Randy
