I know that sounds strange. My receiver (Orange R910) is all PWM. I just got some LEDs from Flytron. These LEDs can use a PPM signal to sync the flashing. Is there a way to:
A) Get the APM to send PPM instead of PWM out one of the outputs?
B) Something I can buy that will generate a PPM signal?
These are strobing LEDs. They flash on their own using a typical aviation flash pattern. By connecting a PPM signal wire between each module, the flashing will synchronize.
