I2C splitter problem
I'm using an I2C splitter to connect more sensors on my pixhawk. When I only connect my external compass to the I2C splitter Mission Planner gives no error. When I connect my optical flow sensor, sonar and external compass I get the error compass variance and compass inconsistent. Does anyone knows what the problem is? I use Copter-3.3.
  • I have exact same issue too.
    Stijn, did you find to solove this?
  • Does this happen on USB only or with the battery connected? I found that too many things on the I2C bus while powering with only USB caused this for me. Once hooked up to the battery all of the problems went away.
    • No it happens also when I connect the battery. The first error I always get is preArm: rangefinder check, normally you have to lift your vehicle 50cm above the ground because the autopilot needs to check if the sonar is of good quality. If I do this the next error I get is compass variance. When I disable the preArm check of the rangefinder the problem is solved and there is also no compass variance error.
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
