I2C splitter problem
I'm using an I2C splitter to connect more sensors on my pixhawk. When I only connect my external compass to the I2C splitter Mission Planner gives no error. When I connect my optical flow sensor, sonar and external compass I get the error compass variance and compass inconsistent. Does anyone knows what the problem is? I use Copter-3.3.
  • I have exact same issue too.
    Stijn, did you find to solove this?
  • Does this happen on USB only or with the battery connected? I found that too many things on the I2C bus while powering with only USB caused this for me. Once hooked up to the battery all of the problems went away.
    • No it happens also when I connect the battery. The first error I always get is preArm: rangefinder check, normally you have to lift your vehicle 50cm above the ground because the autopilot needs to check if the sonar is of good quality. If I do this the next error I get is compass variance. When I disable the preArm check of the rangefinder the problem is solved and there is also no compass variance error.
DIY Robocars via Twitter
May 15
May 14
May 13
May 13
May 11
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
Apr 30
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
Apr 26
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
Apr 23
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
Apr 23
Apr 21
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
Apr 21
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Apr 17
