Hi all,
I’m looking for a straightforward solution to have a quad land on a small outdoor target area of 1ft x 1ft. Fully autonomous. Acceptable accuracy would be +/- 2 inches of the target center.
We know the GPS location of the landing site, which the quad will use as a waypoint to get to the area and start hovering at altitude. Then for the actual precision landing and descent, a visual marker could be used, ideally I wouldn’t need anything electronic on the ground to make things simple (unless it's really cheap as in less than $50 and leads to a much simpler solution). Also all computing systems must be onboard the quad.
I was thinking of combining a Pixhawk, a Raspberry Pi 3 and its V2 camera module (8MP) to do computer vision with OpenCV. I would like to keep things simple and if possible limit the image recognition to basically a color mask + find contours. First the Pixhawk will take the quad to the GPS location. Then in “locate & descend” mode the RPi3 would start scanning and feed the Pixhawk with (x,y,z) velocity vectors to get closer to target and land.
Will this be good enough? Any potential roadblocks that I should anticipate?
While searching on the forum I found a UC Berkeley project [1] that seems related although it’s 2 years old. I also came across the PX4Flow work but I’m hoping I can do without.
Thanks!
[1] http://diydrones.com/profiles/blog/show?id=705844%3ABlogPost%3A1789944
Seems like there are several ways to do precision landings. I like the solution Fnoop came up with.
Here is another precision landing using computer vision (OpenCv) with a phantom 4 pro and interpreting the video stream to stick a landing:
https://vimeo.com/230643360
Just a late-on follow-up, I have a little project that probably does what you were looking for. It does precision landing to within a couple of cm on a printed target using on-board computer. No rangefinder is necessary.
https://github.com/fnoop/vision_landing
Hi Anthony,
I think I also saw your post in the Ardupilot.org forum, but I will reply here as well.
Yes, it seems like 3.4-RC6 requires lidar/sonar for precision landing.
However, you can test the precision landing feature w/out lidar/sonar by using the previous firmware.
Arducopter_PL_Quad_3.3.3-rc2.px4
For commercial projects that require a high level of landing accuracy, lidar is very importan (the baro alt can drift by quite a bit). Currently, we strongly recommend the SF10/A.
Best,
Thomas
Anthony said:
@ Thomas Stone : It seems like a rangefinder is required for precision landing in the ardupilot code. I was going through https://irlock.readme.io/docs/getting-started and only see it as optional.
Have you had much success landing without a rangefinder?
Regarding the slowdown feature, are you just adjusting LAND_SPEED?
Does the slowdown help a lot?
Thanks!
Thomas Stone said:
Meanwhile you can use SmartCamera (original version) and just have to change PYTHON PATH and get your home address in the pl_sim.py
Have fun :-)
Update: the problem seem to be with his version of pymavlink, I just desinstalled and reinstalled using standard sudo pip and I can regain control of the modes.
But now I got an error with the VN_logger on precisionland.py ... I opened a new issue. If I disable the logger ,I can see the target moving on the simulator screen, but it crashed after a while because of the logger. To be followed.
Hello Antony,
I just tried it and it seem that the simulator get stuck in STABILIZE mode without any ways to switch to other modes like GUIDED. This is why you get disarmed because it does not start the motors. You can put rc 3 1450 right after arm throttle and you will see the copter climbing.
I opened an issue on Daniel github about this problem. Stay tuned :-)
@Patrick Poirier - yes I tried, it doesn't help.
Hello Antony
Have you applied throttle: rc 3 1500
@Patrick Poirier - I tried running the precision landing SITL code you pointed at. Setting up the environment is OK, but I seem to be running into the following issue: the AP will disarm after 10s no matter what I do and nothing happens.
Here's a copy of my sim_vehicle.sh terminal:
And in the console window:
The AP automatically disarms after 10 seconds and prints the last two lines. Any idea what is happening?
1
2
3
4
of 4 Next
