I've been reading about Micro Drones claim of 1 hour flight and I have been pouring over some numbers trying to figure out if this is possible with LiPo batteries. My answer is simply no.
I've look at different batteries and different motors. Typically the motors are able to thrust 10g per W. This means that for every gram of thrust needed you are going to consume 0.1Wh (watts per hour). Even this number is slightly optimistic, some motors / props have half of that output others go as “high” as 11-12g per watt.
Let’s use 0.1Wh per gram of thrust.
Now, let’s look at batteries (I’ve compared thunder rc and hk batteries) and the best pack for the punch is about 650 grams for a 8400mah battery (3s). With LiPos you are supposed to drain about 80% which gives about 75Ws for this battery. If you divide the weight of the battery with the Whs you find that you get about 0.11Wh per gram of battery weight.
So, to simplify; just to carry the weight of batteries you will burn up all the charge in one hour. It doesn’t matter HOW many batteries you add. The equation is still the same. However, I have seen that typically LiPo batteries packs more punch the bigger they get, but I could not find any reasonably priced batteries larger than 8400mah.
My dream of building a 1 hour flight octo with 4lb carry capacity is just impossible.
The only possibility I see is to tweak and build a really large copter and gain a few % here and there or come up with another source of energy than LiPos.
Can someone correct my math if it’s off please, or direct me to more efficient motors and batteries?
Thanks,
Roger Larsen
Anyways; here are the motors / props I'm ordering. Skipping the T-motors due to a lot of bad reviews.
I've also seen some strange looking thrust benches. I'll try to build one which does not use a L to apply force to a scale, and place the motor on a long stick attached to a 4kg weight at the end. Place the weight on my scale and read how much it can lift. If you have to much stuff right behind the prop it will give you incorrect readings (since the force of the prop will push the plate down at the scale and counter the thrust of the prop). Kinda like what happens if you put a big plate underneath a helicopter and try to take off with the plate attached (yep, I saw this on Myhtbusters :) ).
2-6 cell batteries (where it makes sense to use them).
ECU:
http://www.hobbyking.com/hobbyking/store/__17135__Turnigy_TY_P1_25A...
Watt meter:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=...
(already have this one)
http://www.smartdrones.de/collections/propellers/products/multicopt...
(15")
http://www.goodluckbuy.com/1555-15x55-carbon-fiber-propeller-prop-c...
(15")
http://www.rctimer.com/index.php?gOo=goods_details.dwt&goodsid=...=
(16")
http://mikrokopter.altigator.com/graupner-eprop-14x8-propeller-p-40...
(Graupner 14x8 e-prop)
http://www.smartdrones.de/collections/motors/products/brushless-mot...
(550kv)
http://www.smartdrones.de/collections/motors/products/sb-m550k-upgr...
(550kv)
http://www.smartdrones.de/collections/motors/products/high-performi...
(650kv)
http://www.himodel.com/electric/DUALSKY_XM5010TE-9_390KV_Outrunner_...
(390kv)
http://www.himodel.com/electric/HL_W48-30_420KV_Outrunner_Brushless...
(420kv)
http://www.himodel.com/electric/HL_W42-25_390KV_Outrunner_Brushless...
(390kv)
http://www.himodel.com/electric/HL_W48-22_390KV_Outrunner_Brushless...
(390kv)
http://www.hobbyking.com/hobbyking/store/__17923__NX_4006_530kv_Bru...
(530kv)
http://www.rctimer.com/index.php?gOo=goods_details.dwt&goodsid=575
(360kv)
I feel I need some more props to test; but these seems to be what people recommend. I did find some 16" graupners but no CCW :/
I'll keep you posted!
Roger.
I don't understand ppl claiming "It is clear that a great many people are spending billions of dollars on the electrical energy storage density thing. Something useful is bound to come out of it."
The fact the somebody is spending more and more money on a technology, usually means it has reached steady limit, nothing quarantees breakthrough. For example, we are spending most money on taxes and banks. They have consultants, research departments. Yet, there is nothing ultra spectacular achieved by new taxes nor banking in the past century beyond idea of bourse money rental, money transfer etc.
Amount of money spent on energy density in batteries would rather mean it is easier to get funding for this sector beause it is easiest to draw imaginative stories around it. What you will get in shops in ten years from now, is leaving research labs right now. And what do you have in the labs? Energy densities raising by 50%, at best.
My idea is build a small 3 phase generator powered by small nitro .049 engine. If this works then the next phase will be to machine a small turbine that will spin from the heat of a butane flame, the motor will spin a simple over-run clutch that will be connected to the shaft of my spare 1200kv motor. :) from there we can build a LiPo charger that will charge each cell individually. I've got the motor sitting around.. I just don't have a small over-run clutch.
I found the perfect source for the clutch!
http://www.tinyclutch.com/d-series-roller-clutches
What does the group think? I can build oversize landing gear and mount the generator there.
I'll only mount the turbine on the quad. I'll test with the nitro motor outside on a workbench.
I wonder if we can build a small generator that runs on butane ? I picture a microturbine spinning a small 11.1 volt 33 watt generator. The generator will be used to charge the primary LiPo power source during flight. This will be needed so we can have power on demand. The small generator will extend the flight.
Not quite what you want but there is a discussion here about slope soaring a helicopter. That would get you your 1hr flight
http://rc.runryder.com/helicopter/t12043p1/
Thanks for all the valuable input. Based upon my research and your input I will set up a test to stop guessing and ensure I can get the most trust per W. Stability and what not will be not measured yet.
This is my test set up so far;
ECU
http://www.hobbyking.com/hobbyking/store/__2163__TURNIGY_Plush_25am...
MOTOR
http://www.rctigermotor.com/show.php?contentid=142
PROPS
A bunch of variations from 12 to 15" in size
Graupner E-prop
ACP SF
LIPOS
http://www.maxamps.com/Lipo-11000-74-Pack.htm
- 2,3 and 4s
The idea is to test the trust with different combinations of volts / amps / props.
I also have some ideas to improve airflow / turbulence around the prop to see if that does anything.
Dimpled props apparently doesn't do anything; so I will not try that.
Before I order all of this, let me know if there are other configurations (motors / props) you would like for me to test. Just keep in mind is that my goals are a stable platform, with large carrying capacity and range. My goal is not to get a super fast and agile platform. I will build the copter using CF parts myself instead of ordering ridiculously priced kits.
Thanks,
Roger Larsen
So, what if you created an octacopter where the you use 4 large props low kv engines and add 4 higher kv, smaller prop engines for stability?
I found some interesting motor / prop configurations;
13x4.5, 7.4v, 6.3a (47watts) with a thrust of 730g. This gives 15.66g/W. A configuration like this might give 30+ minute flight times.
I've got an idea. Try to locate three blade props that are about the same size of your current props. You'll get more thrust so your rpm required should be less. See if that improves your flight time. If that works, maybe we can increase further with a 4 blade prop ? My quadpod uses 5" 3 blade props. I tried 5" 2 blade to see what effect it would have since i had the parts in my r/c parts box... it had less thrust and since I had to throttle up more the batteries did last a shorter period of time.
Maybe we can experiment with that ?
Motors generally are going to be about 75-85% efficient, and the LiPoly technology is what we're basically stuck with.
The two variables which are under your control are propeller FM and disk loading. In this worked example of a 4-pound quad, the ideal power (FM=100) is about 19 watts per gram. If ultra efficiency is your goal, off-the-shelf props are going to disappoint you.
DIYD Thread - The Case For Large-Scale Electric Multicopters
As Jack said, if you made the disk loading light enough, it might work, but then rotational inertia would impact the controllability severely. Ultimately, you're right - the energy density of batteries is still not there yet.
DIYD Thread - Worked Example of Energy Density Solutions
1
2
3
of 3 Next
