when i connect to Ardupilot with the serial monitor i received the following error:
EError: PA7 & PG1 is not reading HIGH
Press Y to continue.
I press Y and gives me the same error.
Everything is ok. Hardware led is greed. Com port has corrected settings. Switch on CLI.
Drivers ok on win7 32 bit.
Do you have any idea ?
Thanks in advance,
Gastone
That means you haven't loaded any firmware!
Please use the manual and follow the steps. You need to download the mission planner and load firmware. What you're seeing is just factory diagnostic code--there is no flight firmware loaded at the factory.
Folks, same issue here on a newly built 2560 model (jDrones sourced). Just tried APM2.0.36 and CLI ends up with the same scenario (
Error: PA6 & PK7 is not reading HIGH Press Y to continue...) as bhboyle's post. And also get the avr stkv2 timeout message when uploading as well.
I have the configuration setup for the right board, baud rate (57600, as 115K shows garbage), and cable, and latest arduino-022 version IDE. So not sure why it's having a problem uploading--time to check the code. Anyone else having luck on a ATMega2560? WIll try it on Mission Planner on windows when I can find a windows box (I'm on Linux).
thanks for your reply. This is what i did. I assembled and soldered the full kit and everything seems ok. Led green on board and blu led on. I downloaded arduino .0022 (last version) install libraries and sketch for piratesng firmware. I modified the config.h for my application and when i compile everything is ok.
When i press "UPLOAD" it gave to me the SYNC ERROR..cannot find the board. (i selected the correct board and com).
The hardware i think is working good because when i press the "boot" function it boot and all led are ok.
Does i need to load something before place the piratesng code?
If you can help me i will be very grateful because it's my first experience with arducopter platform.
I'm trying to find a person that can explain me some things...also if i have to paid something for lesson..not a problem...but i need it.
Thanks in advance and have a nice day.
