Magnetometer orientation
My compass has East and West swapped which I suspect is because the AC2 code expects the compass to be component side down and soldered to the pins on the IMU
I have noticed the AC2 code and CLI doesn't seem to allow you to set the orientation of the mag.
In NG you edited a line in config.h defining the mag orientation.
My compass has the wire mounting option with components up.
Have I missed something somewhere that allows you to define orientation?
Thanks for any help
    You have to set orientation in the APM_config.h if you don't want to use the default orientation. Because you need to set it in the header file, you must use the Arduino GUI to load the software.
    http://code.google.com/p/arducopter/wiki/AC2_Magnetos
    If you are set on using the AMP, just mount the magneto as the software expects it to be. Double-side tape it upside-down someplace and be done.
