Mavlink Basics
So, I'm developing a ground station for iOS devices (iPhone/iPad) and after making a lot of progress, I came upon a major stumbling block. I can not wrap my head around how the mavlink protocol works. The iOS side of the project is easy but i'm stuck on how the messages are generated/formatted.
Btw, I already worked out how to send serial communications to and from the iPhone (Jailbroken) and I'm finishing up an xbee docking prototype that attaches to the back. I just don't have an ardupilot mega yet and won't have one for a couple months. I really want to start working on the program so I need any help that anyone can offer.
Thanks,
Andrew
  • the dock connector requires root access and apple charges tens of thousands of dollars to have a iPhone bluetooth device but wifi is allowed
    I don't understand... why would you deal with a company that would try to rip you off like that?  $10k to use the bluetooth device you already paid for?
  • hi there, I have interested in your project, and i have study Mavlink protocol by myself and also have some experiences of developing Obj-C, can i help you in your project?
  • Have you tried to connect to a APM yet? To see how the arduino handles the code.
  • This is me testing the iPhone serial port using two xbees and the arduino serial lcd example. It works like a champ! and now its time to keep working on the main app!
  • If you do an iOS app I'll be the first to buy it :-) But please include a Bluetooth-Serial option - I use Bluetooth-APC220 convertor (no need for a XBee dock) - the same can be done with XBee and it's much more universal (you can connect anything that has bluetooth - which is, well, everything :-))
    Making a convertor costs $8, dock is clumsy and connector specific...
  • Thank you so so much!!!! its like a lightbulb just went off in my head!
    But basically, I would interpret the heartbeat message using the parameters defined in all the xmls?
     <message name="HEARTBEAT" id="0">
         The heartbeat message just shows that a system is present.
         <field name="type" type="uint8_t">Type of the MAV (quadrotor, helicopter, etc., up to 15 types, defined in MAV_TYPE ENUM)</field>
         <field name="autopilot" type="uint8_t">Type of the Autopilot: 0: Generic, 1: PIXHAWK, 2: SLUGS, 3: Ardupilot (up to 15 types), defined in MAV_AUTOPILOT_TYPE ENUM</field>
       </message>
    And I would write code for each type of message I receive? Like if i got a heartbeat message I would make make sure the GCS is setup for that type of aircraft and the type of autopilot? and set a timer so that if I don't get a heartbeat ever "x about of time" passed, I alert the user to take manual control immediately?
    P.S.- I am planning on making the Xcode project open source on my website but do you think it would be asking too much to charge $0.99 or $1.99 for the prepackaged version on Cydia?
  • It may not help much, but I wrote a mavLink wrapper for android phones. Looking at that stripped down code might give you the insight you need to do the same on iphones
    http://code.google.com/p/copter-gcs/source/browse/# copter-gcs/jni/
    parseFunctions.h is a good start
    The basic idea is that you receive a byte, and push it into mavlink, until it says good decode (gets you a mavlink_message_t& message), at which point you would (example is for a heartbeat packet):
    message.msgid gives you a constant, i.e., MAVLINK_MSG_ID_HEARTBEAT so you know what type to decode
    //Decode
    mavlink_heartbeat_t inp;
    mavlink_msg_heartbeat_decode(&message, &inp)
    and read the appropriate fields from inp struct.
    on the way out (to send), simply pass the fields as (again for a heartbeat):
    mavlink_message_t& msg
    uint8_t system_id = 255;
    uint8_t component_id = 0;
    type=MAVLINK_MSG_ID_HEARTBEAT
    mavlink_msg_heartbeat_pack(system_id, component_id, &msg,type, autopilot);" where
    and any remaining parameters are what is being sent out, as per the headers. After that you can just bang out the bytes over the xbee.
    Anyway, might be worth a look, as it does exactly what you want, except it does it on android.
    Looking forward to seeing a GCS for iOS:)
    Cheers,
    Bart.
