Mavros Override RC Channels issues
Hi community,
1. when I display the topic /mavros/rc/in from command prompt, i got these
header:
  seq: 460
  stamp:
    secs: 1456951630
    nsecs: 476419853
  frame_id: ''
rssi: 0
channels: [900, 900, 900, 900, 900, 900, 900, 900]
2. When I used the RC transmitter, the values are working
 as so
header:
  seq: 3500
  stamp:
    secs: 1456952289
    nsecs: 778270617
  frame_id: ''
rssi: 0
channels: [1495, 1496, 1094, 1496, 1896, 1496, 1094, 1496]
3. When I run rostopic pub -l /mavros/rc/override mavros_msgs/OverrideRCIn '[1500, 1500, 1500, 1500, 1325, 1560, 2000, 1500]'
 /mavros/rc/in does not show any changes
header:
  seq: 3500
  stamp:
    secs: 1456952289
    nsecs: 778270617
  frame_id: ''
rssi: 0
4. Here is my rqt_graph but the /mavros/rc/in is not changing
3691280144?profile=original
  • Hi Vinh,
    I am currently suffer from the same problem. Would you mind share your experience on setting up the mavros system ID, please?
    I have used your method of step 2 to set the SYSID_MYGCS to 1. However, I do not understand your first command
    1.roslaunch mavros apm2.launch fcu_url:=/dev/ttyUSB0:57600?
    ids=255,240
    what is the ids=255,240 stands for? or what kind of command is that?
    Thanks for your help,
    Donald
    Vinh K said:
    Hi everyone, I got the problem fix.
    to setup FCU param SYSID_MYGCS to match mavros system id
    use these commands in separate prompt:
    ids=255,240
    2. rosrun mavros mavparam set SYSID_MYGCS 1
  • Hello Vinh
    Just to let you know that you are not alone :-) !!!
    And yes  it is indeed a mavlink override:
    https://github.com/diydrones/ardupilot/blob/9de1ae8fbbb4cf614bd5920...
    Are you using some kind of Teleop with a joystick ore else ?
