never mind my above statement, i2c should be 3.3v on the original apm2.6 ...
since recently I am using a neo6m GPS +mag combo from rangevideo and that i2c cable has only the logic wires, while vcc+gnd comes from uart connector after looking at the original 3dr leah6 + mag combo I still see only 6 exposed pads vcc, gnd, tx, rx, sda, scl and no 3.3v pin. this confused me to thinking that gps/mag share their vcc, however, after remembering that one of the ways to check if your 3.3v bus on apm is burned is to check the i2c voltage I take my first statement back.
Hmm just looked those pictures more closer.. their text says:
Features: - Use APM firmware and ground station, no need to modify
- No onboard compass, which makes this version ideal for use with multicopters and rovers
But looking more of those pictures I can clearly see HMC5883 compass on board and no clear ways to disable it. Also it seems to have wrong memory components as all Chinese clones have. None of Chinese companies really know what are correct components for APM boards and same continues here.
Board seems to miss all decoupling capacitors for main CPU. I can see a lot of browning outs and weird reboots with this board. Along that it's powersystem seems to miss several protections or at least I did not see those on these pictures.
After some of you guys get those, please post pictures to confirm.
Jani Hirvinen > Dieter GrossJune 24, 2014 at 10:22pm
Ok, why they then say that "No onboard compass" :)
As our real APM2.6 board we really do NOT have that compass. Even cutting down traces have shown some issues on some boards. Best way to disable it 100% is by removing whole compass chip.
and I connected it like GPS- +5V, GRD, TX,RX und compass only SDA/SCL = 6 cables which going to interface GPS I2C see here, I had to cut the internal compass jumper too,
1)i follow your instruction and combine 2 cable in to one cable to plug 2 port at GPS side and 1 port at APM side... however when i connect to the Mission planner it still shows "Bad Compass Heath", its that mean my compass is still not working ? even i am setting it up at my basement , i guess the will only the GPS has no reception but the compass should still work right ? any idea ?? i already cut the JP1 as you mentioned...i just use the cutter to cut it (i never did this kind of cut the circut board before) is it cause i didnt cut deep enough ? any idea ?
2) also for the power module isnt it only use the regular apm board power module but just change the connector is enough ? and follow the same cable order as the original?
3) i am using Spaktrum RX i wonder what i can do to connect the port on the board to the Spaktrum radio receiver.... any idea ??
I will on hold for this and wait for your advise first ... cause i worry i will damage the board
Sorry, I am using the LEA6H with compass from GLB. I will do some more work on it today and post my findings.
Other than that, it's a neat looking small pcb :)
Jani / jDrones
Original ArduCopter manufacturer / developer
Jani,
yes there is a onboard compass but it don't work. to disable the internal compass cut JP1 , first picture top right red arrow
Oh well..
I got one here today to test out but cannot figure out how to connect the external GPS/Compass that came with it
I assume they have to go to the GPS/I2C port somehow combining the two sets of cable into one socket ?
Hi Terry,
I got this GPS http://www.goodluckbuy.com/ublox-neo-6m-high-precision-gps-module-a...
cheers
Hi Dieter
Thanks so much for your info... i think your info is more useful about this board on the net...
i got this combo from goodluckbuy http://www.goodluckbuy.com/miniapm-v3-1-ardupilot-mega-2-6-external...
i have some question really need your help!!
thx so much !!!
Hi David,
my instructions were for a different GPS. For your GPS please follow this threat which have answers to all your questions.
http://www.rcgroups.com/forums/showthread.php?t=2182722
cheers
Dieter
