i got to upstairs and test the GPS and it showing my house position now , however it still showing "Bad Compass Health" i follow this picture to rewire it
but i didnt do the wire soldering like the one i green circled .... is it a must to do so? cause my GPS board seems different then the one on the picture....or the "Bad Compass Health " cause of something eles ? my table dont have any electric right now excpet the board and the monitor ....any advise ?
this set is everything ready to go ... no need to modify ...
thank you so much Dieter for your information anyways !!
Terry Brooks > Dieter GrossJune 24, 2014 at 11:45pm
Thanks Dieter
Yes I spent a little time and figured out the connections on the Mini APM for GPS/Compass however I have no idea which cable is which on the GPS/Compass unit itself
I'm surprised that there is an internal compass jumper on these boards (I hadn't noticed that before) as the spec states 'No onboard compass'. Strange.
Out of interest, did the (external) compass work before you cut the jumper?
Hank Danico > Shane HopcroftJanuary 7, 2015 at 4:31pm
From what I have seen this might be wrong as this video shows the board with a working compass.
thank you for the correction
i got to upstairs and test the GPS and it showing my house position now , however it still showing "Bad Compass Health" i follow this picture to rewire it![3702826584?profile=original](https://storage.ning.com/topology/rest/1.0/file/get/3702826584?profile=original)
Question? Do you have to do this if you have the 3DR GPS?
Thanks in advance...
David, read the threat, its all about the mini apm
see http://www.rcgroups.com/forums/showpost.php?p=28893855&postcoun...
thats your GPS I think?
i give up with this set LOL
i will order from here http://witespyquad.gostorego.com/minireadytoflyer-2-6-v3-1.html
Thanks Dieter
They have the standard connectors for an APM
The green Chinese characters in the first pic means:
The solder pad pointed by the arrow here has the same functionality as the JP2 jumper on an APM. It is used for firmware upgrade.
And white in the second pic:
Telemetry port, pins from left to right are GND, 5V, TX, RX
Hi Ye Wang,
could you please explain this deeper? I thought Jumper2 on the Mini is jumper1 on the apm.
what have this to do with firmware upgrade? Where is jumper2 located on the APM? I upgraded firmware on mini without jp2.
thanks
https://www.youtube.com/watch?v=Zv49LdcaLv0&list=TLgEkk1g42RaI
Shane,
the onboard was not working from the beginning. the external compass did not work until I cut the jumper
The board I got from GLB were sold as version 2.6-external compass http://www.goodluckbuy.com/miniapm-v3-1-mini-ardupilot-mega-2-6-ext...
