Hello everybody,
Here is my problem, my minimosd is all glitching when I increase the throttle, if the throttle is to high or when my ESC "bip" the minimosd just crash and I need to reboot it via the reset button to have it working.
I have two different lines of power, one for the atmega 328P fed by the APM 2.6 and the digital line by a 12v battery... I don't have the xbee telemetry module so tx and rx are both connected to my apm wich is powered by a 5v BEC.
I measured the BEC voltage output when the esc bip and the voltage stays around 5v...
None of the jumper on the OSD is connected except the PAL one cause I'm using PAL video system.
Does anybody have an idea of the problem?
Cheers Lucas.
My experience might help - I had the same issue with the OSD randomly rebooting or freezing. Turned out that the servos was feeding a lot of noise on the voltage and caused havoc on the APM fed voltage line. Try using a separate UBEC for the input voltage. There might be noise induced on the APM voltage feed.
