Hello,
I'm having a weird issue, hopefully someone can help! I am running MinimOSD 2.2 extra copter.
before arming, all OSD values are updated properly. However, as soon as ARM, 2 seconds later everything freezes (values do not change). This only happens when I have the "warnings" OSD item enabled.
has anyone experienced this, or know how to get around it? I guess I could fly without the warnings.. but it's a really nice feature i'd like to use.
Thanks!
Raph
having the same issue with the latest minimosd extra and adrucopter 3.1.5
any update?
Which release candidate did you load? Saw posted that r789 fixed it but I think you have you build the hex...
I loaded the latest firmware but I get some gartbage on the screen did you have the change the character set? if so which did you use?
load this charater set and it is back... https://code.google.com/p/minimosd-extra/downloads/detail?name=Mini...
I used this firmware... https://code.google.com/p/minimosd-extra/downloads/detail?name=Mini...
it all looks good now... will be flying again in the am and will report with the findings...
Flew great today... osd updated fine no issues...
I have a issue which I think is with the RSSI scaling, anyone know the setting for the frSky X8R RSSI port I get it as high as 48% and in the air still line of sight never dropped below 36%... so I figure I have a scale issue ..
using the A1 pin, in adrucopter, 3.3 voltage... noticed a range scale in Minimosd but was not sure if I should change it their..
I am almost 100% with the Y6 FPV in a MRS setup...
Having a bit short flight times... with a 4000 mAh 4s I get maybe 6.5 minutes with full FPV gopro ... and leds...
I am running a high 1 watt 5.8 ghz, and a high gain patch received antenna... had allot of issues with the lower wattage 200mw now it is crystal clear to the end of the RC range...
the OSD is going great and now I got to get more confident with it, but it is great so far...
did you have to update the character also
Great will flash in the next hour... Will be great I have a
try Minim OSD Extra firmware it work fine
I had this issue too, and 'solved' it by loading the latest development firmware. That would be one of the 2.4 releases.
