I just installed the update to MP 1.3.39 and realized that the Dataflash auto analysis is broken.
.bin files I could auto-analyze in the previous version of MP result in a "Failed to start LogAnalyzer" followed by a bad input file message wit this release.
I attached one of my .bin files in question
Any insights?
111.BIN
  • My computer runs an Intel Xeon E5-2630, 16Gb RAM and Windows 7 Pro 64Bit. The Auto Analysis fails on a 50Mb log from around a 25 min flight, with some non flying time before hand. Just tried it again and it killed MP, causing it to close.
    1) Is it best to run this on the BIN or the LOG as it seems to convert the BIN to a LOG before it can start anyway ?
    2) Is there anything I can do to make this work, or are the flights just to long ?
    mp will run fine on x86 (joystick support requires this), the log analyzer will only run on x64 (due to memory issues).
    x86/32bit only supports 2gb of memory, and the analyzer uses a lot of memory.
    if you install python yourself you MAY be able to run the log analyzer however.
  • Not silly at all as it IS a 32 bit program and is installed into the x86 area where x86 programs are installed. The program calls on functions though that are OS controlled and the OS can call on more than 2 gigs of memory.  And yes it is related :) And it comes down to the core function of the OS and how it, for lack of a better word, partitions memory and gives access to memory requests,
    Jeremy Randle said:
    This might be a silly question, but I note that my copy of Mission Planner is installed in the /Programs Files (x86) directory. For some reason I had it in my mind that this is where 32 bit versions of programs were typically installed. Is this correct ?
    I also note that that the Auto Analysis seems to fail on larger files. Could they be related ?
    If so, how do I get a 64 bit version of Mission Planner, or is the program the same and the discussion is solely about whether Windows is 64 Bit ?
  • This might be a silly question, but I note that my copy of Mission Planner is installed in the /Programs Files (x86) directory. For some reason I had it in my mind that this is where 32 bit versions of programs were typically installed. Is this correct ?
  • "Mission Planner" works "fine" on 32 bit as a whole, but the Auto Log Analyzer portion doesn't work so well on larger logs on x86 and as more and more stuff gets logged then the size will grow and as the size grows it is no longer feasible to keep trying to "dumb" things down for older computer to be able to run it. Every day there are fewer and fewer older computers running x86 operating systems. ALL newer PC's are x64 capable and tend to come with x64 windows and only really OLD computers can't run x86 and only pretty much people who upgraded from an old x86 windows or bought an old PC with x86 windows already on it are today running x86 at all.
    It's almost selfish to expect the devs to have to write code that will run on old or outdated systems and x86 is an outdated architecture even if running on newer hardware that is capable of running x64, It holds them back and everyone suffers and let's face it 99% of current [within the last few years] computers are capable of running x64 so there is no incentive to pander to the 1%. Does it suck? Well it does if you're still the 1% but the 99% should not be punished for it.
  • Michael Oborne said:
    the key is x64.
    ie xp is no longer supported. the reason behind this is the 2gb memory limit. a 40mb bin file was failing because of memory issues.
    Thanks Michael. So what you are saying is that 32bit machines running Windows 10, not XP, are no longer supported by MP?
    This would be a bummer.
  • Also you are saying that those that run Win7/8/8,1/10 X86 are going to have memory issues as well. That is good to know for future reference. Thanks for that tidbit of info.
    Craig said:
    Thank you Mr. Oborne for chiming in. And since you're the actual author of said Mission Planner people don't have to take my word for it, they got it straight from the horse's mouth :)
    So "technically" they could format and install XP64 and it should work? Even though XP64 really isn't XP, it's 2000 server with XP's skin, but still :)
    the key is x64.
  • Thank you Mr. Oborne for chiming in. And since you're the actual author of said Mission Planner people don't have to take my word for it, they got it straight from the horse's mouth :)
    the key is x64.
    the key is x64.
  • To your issues it very well may that Micheal changed how the files are uncompressed with 1.3.39 the rest went towards Chuck's post.
    I was able to auto analyize your logs just fine using 1.3.39 myself
    Stephan said:
    I am on Windows 10.
    Craig your response is a bit cryptic. The files are the same as the ones I could auto-analyze with the previous MP versions w/o problems right before the update to 1.3.39.
    Since I am apparently not the only one I count this as a bug in MP
DIY Robocars via Twitter
RT @chr1sa: Just a week to go before our next @DIYRobocars race at @circuitlaunch, complete with famous Brazilian BBQ. It's free, fun for k…
Saturday
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Nov 28
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Nov 26
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
