I just installed the update to MP 1.3.39 and realized that the Dataflash auto analysis is broken.
.bin files I could auto-analyze in the previous version of MP result in a "Failed to start LogAnalyzer" followed by a bad input file message wit this release.
I attached one of my .bin files in question
Any insights?
111.BIN
    good to hear!!
  • @michael oborne I just upgraded to the 1.3.40 release and can report that Auto Analysis works fine again on Win32/x86.
    Thanks for fixing this!
  • Michael,
    I checked the release notes - I could not find any statements that the Auto Analyze function is all of a sudden no longer supported on x86 machines with version 1.3.39. I would appreciate if you could look into this - since it was working fine all the time before with the previous MP versions this should not be such big of a deal. Its certainly harder for us to purchase new hardware w/o prior notice....
    Thanks!
    Michael Oborne said:
    mp will run fine on x86 (joystick support requires this), the log analyzer will only run on x64 (due to memory issues).
    x86/32bit only supports 2gb of memory, and the analyzer uses a lot of memory.
    if you install python yourself you MAY be able to run the log analyzer however.
  • What is the error reported and maybe attach the logs here so we can see if we can reproduce the error.
    oh you said plane. sigh. no experience with the plane firmware but other do so maybe still do it.
    Kelly Foster said:
    I have had problems for months trying to auto-analyze data flash logs on MP, to the point of giving up. I run Windows 7 on a 64 bit Sony VAIO. I tried again yesterday using latest ArduPlane and latest MP and it failed yet again. Short session, smallish log file.
    Kelly
  • I have had problems for months trying to auto-analyze data flash logs on MP, to the point of giving up. I run Windows 7 on a 64 bit Sony VAIO. I tried again yesterday using latest ArduPlane and latest MP and it failed yet again. Short session, smallish log file.
    Kelly
  • Takes a while but it opens fine on my box
    Log File C:\Users\Craig\AppData\Local\Temp\tmpAC67.tmp.log
    Size (kb) 110111.673828125
    No of lines 1438418
    Duration 0:20:11
    Vehicletype ArduPlane
    Firmware Version V3.5.2
    Firmware Hash dc9d87fd
    Hardware Type
    Free Mem 0
    Skipped Lines 0
    Test: Autotune = NA -
    Test: Balance/Twist = NA -
    Test: Brownout = GOOD -
    Test: Compass = GOOD - mag_field interference within limits (11.23%)
    Max mag field length (703.92) > recommended (550.00)
    Test: Dupe Log Data = GOOD -
    Test: Empty = GOOD -
    Test: Event/Failsafe = GOOD -
    Test: GPS = GOOD -
    Test: IMU Mismatch = GOOD - (Mismatch: 0.58, WARN: 0.75, FAIL: 1.50)
    Test: Parameters = GOOD -
    Test: PM = NA -
    Test: Pitch/Roll = NA -
    Test: Thrust = NA -
    Test: VCC = GOOD -
    Jeremy Randle said:
    The file is uploaded here. Thanks for looking in to this.
    https://cloudstor.aarnet.edu.au/plus/index.php/s/VPYOKkgDsDgoXA4
  • The file is uploaded here. Thanks for looking in to this.
  • anywhere that is publicly accessible really.
    Jeremy Randle said:
    I just zipped it up and it is 22MB which is more than the 7MB limit. Should I put it on CloudStore or similar and post the link here ?
  • I just zipped it up and it is 22MB which is more than the 7MB limit. Should I put it on CloudStore or similar and post the link here ?
  • can you zip/rar the log and attach it to a reply so we can take a look at it?
    Jeremy Randle said:
    My computer runs an Intel Xeon E5-2630, 16Gb RAM and Windows 7 Pro 64Bit. The Auto Analysis fails on a 50Mb log from around a 25 min flight, with some non flying time before hand. Just tried it again and it killed MP, causing it to close.
    1) Is it best to run this on the BIN or the LOG as it seems to convert the BIN to a LOG before it can start anyway ?
    2) Is there anything I can do to make this work, or are the flights just to long ?
DIY Robocars via Twitter
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
yesterday
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Saturday
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Thursday
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
RT @DAVGtech: Another incident: https://t.co/G1pTxQug6B
Oct 23
