motors keep beeping at me
hi , been try to get my to my hexa to arm but every time i plug the battery in it beeping at me, they are turnigy plush 30a, i know all my escs and motors work as the hexa was working with another board, im running the lastest firmware, ive calerbrated them manually, in the manuel it says the beeping is caused by throttle not being at zero, when i calerbrated the radio low pos for the throttle is around 907-905, im not using a pdb so i have my bec wires pugged straight in the outputs with the red wire disconected, battery is fully charged, its got stumped
  • I'm getting the same problem.  I get the confirmation beeps when I calibrate the ESCs but the motors keep beeping.  Can't arm or get them to spin.  Don't know if this is related but when I run the Test function in the CLI, there is no option for the pwm test on the menu.
  • mine is officially driving me crazy!!! seriously what is up with it. they only stop when i pull out the signal cables from apm outputs, all 6 of them. i have them connected to output 1,2,3,4 and 7,8. i pull these out and beeping goes away, but useless diagnose.
  • yea i forgot to say, im gettin a missing rc  something error every time i go in the radio set up tab in the apm set up menu, cant remember what the error was called
  • ive got the esc to calerbrate, they power up and spin but as soon as i disconect the battery and then reconnect the battery my esc's just keep beeping about 1 second apart, the weird thing is if i load the hexa config on to the board i cant calerbrite the esc's until i remove the signal wire from pin 8, any ideas what the problem is, im sctahing my head over this
  • Hi glen, I'm facing the same problem for days now. Can't figure it out. I run a hexa 25amp plush. Prior .55 firmware it was running ok. Good to see a few guys getting this error and hopefully Jason and the guys could help out on the problem. Paul.
