Hi All,
My first post here as I intend to move away from Naza V2 to Pixhawk.
After 'working the problems', I managed to get a green light on the Pixhawk (yippeee!) but I cannot seem to start the motors.
I connected the Pixhawk to APM Planner > Inititial Setup > Failsafe, Radio IN bars are moving but not the motors. I checked again that the servo cables are plugged in correctly as per quick start, and it looks correct to me. Any suggestions?
Also, while I am here, is it possible to arm the Pixhawk despite being indoors with poor GPS?
Many thanks for your help!!
Well motors are now starting, re-ran all the calibrations and they now work. Hurray! Thanks for all your input!
I have a separate problem now which is the motors do not start in-sync even though they have been calibrated, that is another topic.
Hi there, well I managed to get motors turning, yippee!! The problem seemed to be that ESC calibration had not been done (did not know it was a pre-requisite). All good you say.. . well now I can get the motors spinning when connected via USB but cannot seem to get the Pixhawk to Arm; it's led light is flashing green but will not arm - throttle to bottom left, click on safety switch, nothing.. . any ideas?
Not easy but I am aiming for success! :)
I had same problem, as it turns out I have to power the output side of Pixhawk with another reg,, as I'm using Multistar OPTO ESC's,, and Pixhawk only has 0.9V on output side... as soon as I powered the output side,, it works...
Welcome to the 3DR R&D TEAM!!!
Hello I had the same problem. insured you that you have made the right connection to Pixhawk/ motors. if yuo have a copter you must link the cable in 1-2-3-3-4-5-6-7-8 side and not in 1-2-3-4 side (white)
