Hi everybody . hope someone can help
I am setting up my bixler with APM2.5 2.74 and Open LRS 1w .
I notice when looking at the HUD when I turn on TX the ground speed indicator went to
70 (this is when plane is sitting still on my living room table) when I turn off tx it drops to zero .
I have tried turning tx on from 10m away but same results .
Any ideas
hi again
I check out the GPS ,I got the same problem even when GPS was disconnected.
Next I load a old version of arduplane , but still same problem , so next I did a system reset .
it looks like the apm firmware was corrupted .
I have reset the APM I load quadcopter firmware first and all was fine even when the radio TX was
next to APM.
so then reload 2.76 adruplane . I am getting a reading of 2-3 on the airspeed even on the bench is that normal ?
cheers again
thanks guys , I will try both ideas later today and let you know
how I get on
cheers
That's probably just GPS jibberish from being under a roof and noise from your LRS.
