Ok, I was contacted today to see if its possible to build a quadcopter that could flight for at least 10 minutes with a small camera recording a flooded tunnel (it has artificial illumination) that has 4 x 3 meter and the bottom is water.
It his feasible? They don't want to control the quadcopter, they want it to go inside this tunnel and go back after X minutes, to survey the tunnel.
Some computer vision maybe? Or small LIDAR? But how? How can I contact? If is there someone that can do this, I can hire you for this task.
ALK
Is the water relatively still? If so a floating device/boat would be much simpler then a quad. Flying a hover based craft like a multicopter inside a relatively narrow tunnel like this is going to be very difficult, especially with all the turbulence created by the propellers in the closed area. And regardless this job would require dedicated hardware and software. No off the shell solution that I know of would do this this automated.
If the job has a budget for development I would look at getting a Hokuyo laser range finder with a >180deg beam and point it up into the ceiling so that you would scan the inside circumference of the tunnel and use that to position the copter accordingly.
Sonar would be the way to do this, but you would need a custom flight mode coded for the APM.
Altitude hold with sonar keep a multi-rotor a fixed distance from the ground, you'd need a similar mode but in multiple axes to keep it a fixed distance from the roof and walls.
If the people needing the survey done have deep pockets it could be a fun little task for someone who knows the APM code well.
