My Bixler 1.1 Drone Project
Hi all,
I newly developed a fixed wing drone with Bixler 1.1 from hk.
Below picture is autopilot cockpit module I designed for pixhawk.
I had to extend front section of the cockpit from its original length to fit longer pixhawk into the cockpit.
Also note the GPS mount and pitot tube mount.
3691328800?profile=original
You can see the difference between the original cockpit and 3d printed cockpit.3691328842?profile=original
When finished, all the components are nicely attached to the cockpit as shown below.
3691329017?profile=original
3691328986?profile=original
Most of the components are mounted inside the cockpit and I hope this may help reducing the drag if mounted externally.
Hope I can report some good news later.
Thanks,
Kyu
  • Thanks for your comment.
    Unfortunately, I don't have pixracer now but will look at it.
    Johnatan said:
    Nice build. Have you seen the Pixracer? It is much more smaller than the Pixhawk 1 and has better sensors.
  • Nice build. Have you seen the Pixracer? It is much more smaller than the Pixhawk 1 and has better sensors.
