nav_pitch offset error in FBWA
Hi All,
Running DX8 with spektrum satellite on pixhawk, latest firmware.
Radio has been calibrated 3 times all perfect 1500 centre sticks.
I am however getting a -2.0 offset on nav_pitch in FBWA mode. Any ideas how to fix this without adjusting the trim values on the radio as it needs the correct trims for manual flight.
I have tried increasing the deadband zone on RC2_DZ from 30 to 60. This didnt help. I also changed the RC2_TRIM from 1500 to 1455 this does change the value close to 0 but i dont see why i should do this. As the RC calibration screen is showing 1500 as neutral very accurately and repetitively.
3691273390?profile=original
3691273482?profile=original
Help would be greatly appreciated. Thanks
  • This nav offset looks like it is from the STAB_PITCH_DOWN parameter.  According to the wiki this is a pitch down applied to the plane in FBWA when the throttle is below TRIM_THROTTLE.  This is meant to help maintain airspeed when hands are off.
    Hope this helps
  • great!.....It knowledge cost me many "&%!* in my pants" moments, and crashes. It was a pleasure to help you.
    ....happy fly from Peru.
    (edited by moderator)
  • Hello again guys!
    Firstly, I would like to thank Juan Pablo Gayoso for the great tip he gave me in getting my wings in the air. Pablo, today I managed to get it right following your advice.
    In result the plane flies great!
    Thank you,
    George (Gastaroll)
  • Apparently , auto-Trim function has to work, like you mention. but I read many comment about the manual trim gives better result than auto-trim. I never used that function, so  I can not give my personal opinion. I only have experience made all manually.
  • Thank you Juan,
    Thank you very very much for your reply.
    Just to clarify... I will use trim_auto and after the new trims are saved I should keep the physical trims position of the elevons while keeping the trims on the RC to neutral. Is this correct?
    After I finish the trim_auto procedure should I center the RC trims?
    I believe the following video explains it but I was not quite following. https://www.youtube.com/watch?v=ucy6VnlMHy8 ;
    Thank you again,
    George.
  • The likely reason is that you didn't trim your plane before.You have to trim the control suface manually, the RC have to be in neutral position.....
  • Hello,
    This is driving me crazy! Please help me too as I can not get around it. When I switch to FBWA the plane pitches up a lot, so much it goes vertical.
    Any help is greatly appreciated.
    Thank you.
  • Hi Nigel
    Could you resolve the issue? I have the same doubt.
    Kind Regards
