So I am about to try using AutoTune but want to make sure I know which position the switch should be in. It is only explained as "Put your switch in the High position to engage auto tuning". Can someone advise approx what value I should be seeing in the High and Low positions in Mission Planner? I use a Futaba and they aren't always in line with the rest of the worlds view on channels etc. Really, as technical as the APM and its documentation is, I would think that it would refer to a PWM value as opposed to "High" or "Low"
