I just noticed this at the Chinese on-line retailer, ThanksBuyer.com
They are pricing the bundled versions attractively. Obviously made to compete against the APM micro 3.1
If anyone makes the leap, perhaps you could keep us informed on your experiences.
Happy flying all!!
2. Are you using a brushless or servo gimbal? Servo gimbal the apm may power them. Brushless gimbal will need to be connected to the proper power source, while the signal wire will plug in to the apm.
3. If you are using an external controller but want to manually control pan/tilt/pitch, then connect signal wire between apm and controller.
4. Or you can bypass apm altogether and plug directly in to your receiver. Which this is nice if you will run a separate camera radio such as the inspire.
Have not gotten to try all the modes yet as the quad I am using this on was grossly in balanced so I had to tear it apart and start again. Ready to fly again so hopefully I will get a chance to fly this weekend.
Hope this helps.
1 i would like to know if this controller supports gimbal and where to connect the wiring,
2 is it safe to use both power module and esc with bec togeather?
Anyhelp would be appriciated thankyou
1, I believe you can manually control your gimbal through this and any apm based flight control, but it won't do it automatically.
2. I wouldn't risk it. Currently my flight control is powered by bec only. I would say one or the other, not both.
loss of control, (1:10)
https://www.youtube.com/watch?feature=player_detailpage&v=MwdL9...
I like this board connectors, easy to find and looks more safe than the Pixhawk ones but this one is 8 bits.
Auto Tune:)
https://www.youtube.com/watch?v=n0mrXfE0AFk
Scott Meese looks like you already figured it out but here is a nice diagram on the wiring, shows the compass and the compus IC socket. Below that is the pin outs
Yeah I just posted, I just noticed people were talking about it so thought I would post what I found, sorry for the late insertion to this thread but it may help others too. I sure would love it if 3DR would get into the smaller sized FCs too, I would surely pay more for better support and documentation from 3DR over these china unsupported products. Maybe one day.
