no power to RX?
Hi Everyone,
I've just finished building my ArduCopter but on powering up i don't appear to have any power going to by RX (turnigy 9x8c) - i'm just tripple checking everything now but was wondering if there was something obvious i may have missed?
  • OK, first basic test completed and everything is spinning and trying to get off the ground, so will be out for the first test flights tomorrow. Thanks once again for all the help everyone.
    took a little while to figure out as the power board had been soldered up differently from the instructions (i'd ordered the soldered kit) so i had to pop the connectors out of the plug and replace back in the correct order.
  • OK, had a nice little envelope waiting at home for me this evening - thanks so much Chris - so I now have a working RX once again. Must have been some dodgy ones from HK before :(   i'll make sure to pop out and pick up Wired for the next few months by way of saying thanks.
    i've managed to arm the motors and can get them all spinning up but as i'd calibrated the ESCs with my 2 channel gear during the RX troubleshooting stage, I would have thought that i'd need to recalibrate them again. I think this should be done using the RX directly still as i can't see how it could be done in the configurator. Can someone confirm for me before i rush ahead as this was where something went wrong for me last time..
    i think i need to plug each ESC into the RX in turn as calibrate just as i would for a "normal" ESC.. is this correct?
  • Hi Guys,
    ok an update here - got myself a multimeter and have tested the output voltage from the APM to the RX connector, and its reading 5v (well, 4.96 to be precise) so it looks like the problem can't be with the kit or PDB, so it must have been that i had two dodgy turnigy RXs ;(
    As Chris had kindly offered to send me his spare (and known-good) RX hopefully that will be here soon and i'll be able to give it another test. Fingers crossed.
    seems i've been unlucky with turnigy this time as the TX lipo i bought at the same time seems to have a faulty cell too :(
  • thanks for all the help so far guys - especially you chris..
    just one thing more to check - I am using all the 3 pin connectors from the ESCs and connecting into the power board - all the example pictures only show a single ESC - but I assume its correct to connect all 4 ESCs to the deans and all 4 normal "RX leads" from the ESC to the connections on the power board - i dont need to remove any of the wires from the 3 pin connectors?
  • Thanks everyone,.
    update so far
    Both RX's out and on their own seems to be a no-go, nothing, just a brief flash of the red led as power is connected and then nothing
    All 4 ESCs and motors out and connected to my 2 channel spectrum gear - all ok
    Arducopter connected to configurator is reading data and all sensors seem to be ok (not tested GPS yet)
    all 4 ESCs beep when connected to copter - but still no response when sending commands to motors from configurator
    So if i'm correct, so this would suggest a faulty power distribution board? unfortunately i don't have a multimeter but am thinking it would be useful to have one.
    i think my logic is sound as above, at least the most expensive components (Ardu,IMU,ESCs, Motor) seem ok i'm just out a couple of $9 RXs
    Is there anything else i can do to confirm if its the power board? or should i now take this up with fahpah?
  • Pictures (hopefully) - had some real issues getting these to upload..
    hopefully i'm just snow blind to all these connectors and its something obvious
    When using official ones it looks like here:
    When not official, all the cables will have signal, positive and negative wires, so all them will feed RX.
    The power for RX came from the I/O ports from APM. Are you using the official RX cables from ArduCopter kit?
