Not being able to setup FailSafe properly
Hello all,
I have the latest revision of the APM code installed, and use a Futaba radio set.
I got the Throttle Failsafe value set up propelry so the APM goes into Failsafe when i switch off the Tx.
However the modes do not change as I want them to.
What seems to happen is that when I switch off the Tx, the mode remains to what it was earlier for about 20 seconds. After that it goes to RTL.
I want the mode to instantly go into RTL, as if i enter failsafe form Manual Mode, 20 seconds in Manual may lead to a crash.
I tried to enable the SHort and Long failsafe values, but that did not help.
Please help !
Gaurav
  • What is the final conclusion on this? I was flying today for the first time in months. I installed the latest software on my skywalker with params from the download section. I guess the 6ch spektrum receiver wasn't happy inside and was losing connection. I wasn't far away at all but I could see when it would lose connection it would jitter and go into circle mode and then sometime after I would regain control. It was difficult to land. I've moved the Rx outside the plane but I'm doubtful if I have things set right. I don't believe I can't set the fail safe on my AR6110e Rx so that it outputs the right value to trigger RTL so I will have to rely on throttle failsafe?
    I noticed in my settings that the FS_GCS_ENABL = 0
    FS_LONG_ACTN = 0
    fS_SHORT_ACTN = 0
    THR_FAILSAFE = 1
    THR_FS_VALUE = 950
    Is this correct?
    When I watch the Modes screen in APMSetup it says Current PWMP 8: 901 when I turn off the Tx. For me that is Flight Mode 1 CIRCLE
    My other flight modes are:
    Mode 2 STABILIZE
    Mode 3 AUTO
    Mode 4 RTL
    Mode 5 FLY BY WIRE Q
    Mode 6 manual
  • On the failsafe document page it has the value 1 for both RTL or if you want to return to your original flight plan. I think this is an error. Can someone please update this as well as include what the other values do?
    I need to confirm fail safe values to have it activated . THR_FAILSAFE = 0, THR_FS_ACTION = 1 Is this correct?
  • Doug,
    Ok Yes i know both things
    a. Control surface are mixed on to all modes
    b. I know about the hardware mux. My Manual is mode is not set to the hardware Manual. Plus the same issue happens when i enter failsafe via Stabilize or FBW.
    Currently I am checking the mode status only by looking at the APM Planner . Well how else can I know that the code is actually into Circle ( at short failsafe ) ?
    Thanks for looking into it. I will feel much more confident, if we can have this report back correctly.
  • Thanks Doug for your help ( i need it ! ).
    I am using  APM V2.26 My board is the new 2560 one. IMU shield is Rev H
    I do not have telemetry installed on my setup.I am checking the fail safe procedure on ground, via my USB cable connection.
    I am checking the Flight mode on APM Planner, on the Flight planner tab.
    I have no problems in having the plane go to Circle mode first for 20 seconds, and then go into RTL. What i do NOT want is the current setup, where the plane remains in manual mode for 20 seconds. That will for sure lead to dangerous orientations !
    Do let me know if you need any other info from me. and Thanks again for your help !
  • Thanks Doug,
    Yes. am sure its not switching to Circle.
    Suppose I am in FBW-A mode. and switch off my Tx. The APM detects this ( as I can see it under Tests>Radio ).
    But the mode remains unchanged. After 20 seconds the mode goes to RTL.
    If I enter Failsafe via Stabilize mode,then also the mode remains stabilize, and after 20 seconds gets into RTL.
    Please help me on this as I need to get the mode switched to RTL reliably.
    Thanks !
    Here are some of my settings :
    THR_FAILSAFE  = 1
    THR_FS_VALUE=975 (  My Failsafe throttle value goes to 969 )
    FS_GCS_ENABLE=0
    FS_LONG_ACTN = 1
    FS_SHORT_ACTN=1
    Long and short failsafe action values only affect higher (auto, guided, etc.) modes.
    When a short failsafe occurs in lower modes the mode will switch to Circle (which keeps the plane in a gentle bank)  mode, and then after 20 seconds will switch to RTL.  Are you sure it is not switching to Circle?  Do you have the throttle failsafe enabled?
