OCTA-V vs traditional OCTA for AP
I need advice on what airframe to choose for Aerial photography Octa.
It will be carrying about 2.5-3.5 KG payload of gear
What are your inputs on OCTA-V versus traditional OCTA (spider shape) ?
I haven't seen many OCTA-V projects, but one is impressing.
how does it behaves being a-symmetrical, compared to a symmetrical spider-OCTA ?
doesn't the V-octa have also a-symmetrical response ? (faster response on pitch than on roll, i.e.)
  • Hi, can you please provide me information about your build, iam interested to build a octo-v.
    Thanks in adnvance
    KR
    Mie Must said:
    Hi patrice, need some help on my Octa V build here. The set up seems to be good n got everything in order for APM1 2560 board. But it yaw to the left during take off and as i slight increased the Throttle it flip over to the left n crashed. Tried erase and reinstall the 2.7.1 firmware and re-setup everything but again there is no improvement. S.O.S.!3692496363?profile=original
    Hi, I need advice on what airframe to choose for Aerial photography Octa. It will be carrying about 2.5-3.5 KG payload of gear What are your inputs o…
  • Have you seen the Octo-V-Tail setup?  Similar to an Octo-V, but the V-tail arrangement gives much better yaw response.
  • Hello
    I have a 1000mm Octo due in stock on January 15th.
    Two camera mount options are available.
    http://shop.carboncore.co.uk/Octo-1000-Octocopter-Multicopter
    Is an Octo-V the type with four arms that split into V's? If so I can't see how these can respond properly to the changes in motor thrust as the inners arms will twist.
  • Thanks for the videos, i know them :)
    seems your props are smaller than 12", right ? maybe 10" ?
    I'm looking for some good information on the difference between them... OCTA and OCTA V
    Thanks !
  • With an OCTA you cannot carry 3.5 KG !!!!! That's too much and for that you need 16 motors.
