I have upgraded to APM 2.2.1 via APM planner.
I am running two XBees 2.4Ghz at 57600 and they work great in loop back, not one dropped packet.
All config is default.
When I try to connect using the latest version of HKGCS I get the startup messages, but then I only get the Mavlink heartbeat, I don't get any GPS, attitude or other data.
I'm pretty sure I've changed something, but I can't think for the life of me what. I've tried two laptops and a stock new installation of HK GCS.
Appreciate any help.
D3690879869?profile=original
    have you checked your GCS transmission rates.
    I had a similar problem some days ago with APM-MP. Problem is now fixed on latest codes and they are changing those rates automatically.
    I was able to see raw sensor output but not actual AH/Gauges etc. Let me know if you have similar problems
  • Hi Peter,
    Ive tracked this down to an intermittent fault, probably thermal.
    Will report back. Ps they are series 1.
    Thanks all,
    Dave
  • I am using Xbee Pro ver 2 and there has been a thread elsewhere about setting them up on this forum. I did as suggested and it worked for me and I could use HK's GCS and planner.
    Which version of Xbee do you have (ver 1,2 or 2.5)?
    Peter
  • Hi Paul,
    Do you mean the attitude, gps and waypoint tabs?
    Ive dialled them all down to 1 and back up again,
    No luck.
  • Hi Ritchie,
    I thought it was 57600 now? Thats what the wiki says.
    I beliebe the US guys couldnt run their 900 Xbees at 115200.
    Happy to be wrong?
    D
  • Hi Peter,
    I have a solid blue on the MediaTek.
    I have a solid red on the IMU.
    If I turn the plane off I get a WARNING LOST CONNECTION verbal message, so the plane is definately transmitting back.
    I've tred this 20 or so times, resetting the APM etc, no joy.
    Regards
    Dave
  • Default transmission from APM is 115200 have you set it in the config?
  • Don't think you get any real data until you have GPS lock. Are you sure you have waited long enough for lock?
    Peter
