Hello,
I am trying to create a custom ground station that could take off the Quadcopter when a camera detects a predefined target. Basically, there are a camera, a computer and a Quadcopter. The computer sends MAVLink commands to the APM3.1 and no remote control shall be used.
I am running a C++ program that arms the Quadcopter with MAVLink but I can't manage to make it fly.
I first tried to override remote control with RC_CHANNELS_OVERRIDE MAVLink command but the Quadcopter does not answered to my request. I then tried with MAVLink missions. I succeed in sending mission to the Quadcopter (I can see them with Mission Planner) but when I switch to AUTO mode, nothing happened.
I'm probably missing something but I've been looking around for a while and I didn't manage to find anything. If you've done that kind of things and if you've got some time to spend for a newbie, any help would be warmly welcomed.
Thanks.
Hello Alexander,
You first have to arm the Quad. For that, use the arm mavlink command COMMAND_LONG (#76). Then, simply use the RC_CHANNELS_OVERRIDE (#70).
The thing is to use the correct GCS_ID so that the Quad will recognize you ;-)
Thanks for the tip on AUTO mode, i'll try that.
Cheers
Hi Valentin,
What's the correct GCS_ID you used?
Hi Valentin, can i get more information on how you were able to arm the quad using #76? Also i am trying to use SET_ROLL_PITCH_YAW_THRUST ( #56 ). Currently I am able to request for IMU data but I am still trying to send commands to the quad. Any help/input is highly appreciated. Thank you!
Suresh,
The trick is to use the #76 mavlink command with the MAV_CMD field set to the arm/disarm command (400).
Then send the MAVLink command to your QUAD, using the correct target system / target component.
Good luck !
Valentin,
Thanks for the reply. Based on your post, I was able to find out that command and the 400 with parameter 1 to arm and 0 to disarm.
However, I am still unsure what is the line in code to invoke. With the given library files, mavlink_msg_command_long is not recognized. Can I get some guidance here?
I just started coding in mavlink several weeks ago. Your help is highly appreciated. Thanks!
Hello,
Thanks for your answer. I will try to use those commands to control APM.
Cheers
