Pixhawk 1MB flash limit
This is a discussion for the 1MB flash limit issue so that we can consolidate any discussions and concerns about it in one place.
To give some background, all Pixhawk (and compatible) boards use STMicroelectronics's STM32F427 as their main CPU.  This CPU is advertised as having 2MB of flash space (flash is where the ardupilot software is held) but we have discovered that early revisions of this CPU (RevA, RevY and Rev1) have a hardware problem and can actually only hold 1MB and if we use more than that they start exhibiting USB communication problems.
Now currently APM:Copter-3.4 is 0.9MB so it's under the limit but as we add new features it grows and if it grows above 1MB users will find they can't reliable connect the ground station to the board using a USB cable (wireless would still work) which could make it very difficult to configure the board, download logs, etc.
We think many boards (perhaps most boards) out there are the early revisions (A, Y or 1) which suffer from this problem.  All the boards on my desk have this problem and you can check your board by following the instruction also shown in the video:
  • Ensure your Pixhawk (or compatible) is loaded with a recent version of ardupilot (like APM:Copter-3.3.x)
  • Connect with the Mission Planner
  • Go to the Terminal screen and select "NSH" on the drop-down on the left, then push the little green connect button beside the drop-down
  • type "ver all" and press Enter quickly into the terminal (the "Overtime in task 19" causes the MP some troubles)
  • look for the "WARNING! Revision Y has a silicon errata".
Some very recent boards do not suffer from this problem.  For example all Solo's are fine as are the XRacer (aka PixRacer) boards.
Before panic ensues I'd like to say that although APM:Copter-3.3.2 is already 90% of this limit, remember we've just done a release and we will put effort into keeping the code size under 1MB.  So for example, I can guarantee that APM:Copter-3.4 will fit and hopefully Copter-3.5 too.
Still, when you're shopping for your next Pixhawk you may consider asking the manufacturer if they are using the latest Rev3 STM32F427 processor.
  • I have just check all my Pixhawk.
    The result is something like that Octa:  STM32F42x, rev.A / #1 Quad: STM32F42x, rev A / #2 Quad: STM32F42x, rev. Y--bingo! / Big Hexa: STM32F42x, rev.1 / Small Hexa: STM32F42x, rev. A.
    One from five Pixhawk has revision Y errata!
    All of devices said " This device can only utilize a maximum of 1MB flash safely".
    • CUAV PIXHACK 2.81, What ever PX4LITE
      Both of them:
      "MCU: STM32F42x, rev.1
      Warning Warning Warning !
      Revision 1 has a silicone errata
      • Did you mean this PX4 Lite ?
        • Yes, but meanwhile realized, that none of my other PX is coming with a rev.3 as well.  All of them A,Y,1 (A @ old 3DR 2.4, Y @ AUAV-X2, rev.1 @ PIXHAWK LITEv2), so I bet, you don´t even need to look ;-)
  • Randy. I think we need to clarify. To date there are 4 revisions of this chip. A, Y, 1, 3. Rev 3 is the only one that is not affected by this bug.
      Phillip,
      Thanks I've corrected the revision names above!
    • Just forgot, I´ve made a pic which fits to your post .Only the A rev. is missing here. The right one shows the PixRacer rev3 STM
      3702608356?profile=original
  • thank's for advertise about this Randy.
    I check my HKing pix and many lines "overtime in task 19" appears but not warning message, It's that's OK?
    • Did you type:
      ver all<enter>
      quickly between those overtime messages and receive some output? Ignore those overtime messages in this context.
      • yes, I did it, I'm going to repeat, in case.
        PD I repeated and now I have the err msg :(  , thank's for your reply L
