Pixhawk bad power circuit after crash.
I had a crash last week with my quad and although it was not too violent and my (3DR) Pixhawk was mounted on a soft foam I think one part of the power circuit was broken. Now my 3DR Lea6H + Compass is weakly powered (led is weak, no GPS fix and compass bad health).
With my multimeter I measured low voltages (0.7V) on Telem2, Serial4/5, Serial3 (GPS), I2C, and others. Telem1, sensors, buzzer, switch are all working well. I had a look at the schematics, and it seems that "VDD_5V_PERIPH" no longer gives 5V power.
To check for bad solder I connected my multimeter to the Serial3 power output and tried to slightly press with my fingers on the components of my Pixhawk -> the voltage did not moved from 0.7V. On the schematics, sheet 6/12, I have seen that two components can be the source of this problem :
- an IC : U602 BQ24315,
- a capacitor : C618 100µ,
but I didn't manage to locate them on the Pixhawk PCB.
Can someone help me with this issue ?
As a workaround, what do you think about powering all those peripherals with a UBEC of an ESC ?
Many thanks,
François.
  • Hi,powering the 3Dr Lea6H with a UBEC will work. But does the pressure sensor works? according to sheet 6 (in schematics) it's also powerd with VDD_5V_PERIPH?
    chris
    • What you see page 6 is an analog "pressure" port (not the sensor), namely "ADC 6.6V" in the Pixhawk case. The pressure sensor (MS5611) is powered by VDD_3V3_SENSORS according to the "Sensors" sheet.
      I had a look further and it looks like my BQ24315 is working well (5v output). So two options in my case :
      - the BQ24315 is not well soldered,
      - the circuit is almost broken somewhere,
      - after the BQ24315, the power circuit systematically continues with two components (for almost each connector) : a filter in series (KNH16C104DA5TS) and a zener diode in parallel.
      I think the third option is the most probable, maybe a shorted zener diode that drains the current. It would explain the 0.7v I measure, corresponding to the shorted zener. I will test them this evening.
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
