Their docs at
http://copter.ardupilot.com/wiki/common-optional-hardware/common-servo/
say this
[QUOTE]The traditional way to control a servo only works as part of a mission (i.e. AUTO mode).[/QUOTE]
So, seems like you can't set a knob on your radio to control the servo for tilt mechanism?
Please tell me this is a joke and there is a way around this.
I just finished building a FPV build with this expensive controller to find I won't be able to tilt my cam. WTF?
  • You may have a better look at the wiki...
    In the Gimball settings, Tilt is Output 9 (AUX1 of PixHawk), input 6 (RC6). And it works, unless you do not supply power to the servo rail AND forgot to set RC6 to None in the Advanced Parameters settings.
    Marc
    • Ah a day saver right there, thank you!
      I'll be looking into that. At least I know it's possible now even if not exactly clear how :)
      I have provided power to the motor outputs since I use 4in1 ESC and it comes with bec to one of the motor connectors.
      Would be fine if I power the servo from the AUX OUTs, given that I have that power from the motor outs?
      I know that generally pixhawk shouldn't power servo from it's own power, but in this case we have 2 sources
      - 1 from the power module
       - 1 from the bec connected to the motor out
    • You can control it with a knob or stick for that matter.  if your mission requires the gimbal to point a certain way it will override your manual input.
      David R. Boulanger
